Windows 7: Sound output asleep after about 20 - 30 minutes
29 Dec 2013   #1
cuevision
Windows 7 64 bits
I read a lot about sound and the pc getting asleep. However my problem can not be found. Hope anyone of you recognize my problem and could be of any help:
The pc is set up to NON-Energiesave. THis means I have set up all possible components to keep alive, not sleep.
For my flightsimulator, I have setup several sound systems. These soundsystems must all be standby for immediate sound. E.g. call outs in a landingsituation. When the sound has to respons, I noticed that the sound that has to start up is missing about 1 second of the sound. I have looked around for hours also in the Bios. I cant find any sound related functions that cause it to go a sleep.
So does anyone can tell me where I have to look or check to keep de soundoutput ALWAYS to ON
Thank you very much. Hope this will have a solution.
Best regards,
Ed
29 Dec 2013   #2
fireberd
Does this happen with ANY sound from the PC or ONLY with the Flight Simulator program?
30 Dec 2013   #3
cuevision
Windows 7 64 bits
Hi Firebird,
Thanks for your fast reply!
Ehmm have not tested that. Will investigate it today.
Thanks and regards,
Ed
02 Jan 2014   #4
cuevision
Windows 7 64 bits
Hi
It seems to be a behaviour of the onboard sound. What I have done now is having an enpty made wav file, continuous playing. Until now, this solve the problem it seems.
Thanks and regards,
Ed
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
Gigabyte HDMI output to Yamaha receiver - no sound output
GA-890GPA-UD3H (rev. 3.1) GIGABYTE - Motherboard - Socket AM3+ - GA-890GPA-UD3H (rev. 3.1) (Note 3) Simultaneous output for DVI-D and HDMI is not supported. What I'm trying to do is output just my sound to the receiver via HDMI cable, but still use the DVI to my monitor...
How can I get sound output from sound card when streaming video?
I get sound from the mic of course.but I would like to get sound straight from the sound card too when I want to.I don't know exact model,but it's a realtek HD on board sound card.Acer 5551 series laptop
no sound output on tv through hdmi ??
Hi I have a HP pavillion dv6 and cannot get sound to transfer via HDMI ? I have icons for Headphones/speakers and bluetooth handsfree but no icon for HDMI how do I restore icon as i think this may be the problem ? Any shortcuts - advise will be appreciated on my old laptop there were...
Sound Output
Hi, I'm a college student with a desktop computer. Whenever I come home, I leave my speakers at school. I used to have Windows Vista. When I'd come home, I could listen to music without headphones or speakers. In other words, sound would come from my sound card. I now have Windows 7, which...
Limit Sound Output
I was wondering if there was a way to limit the master volume output. My teenager's do not understand that there are volume setting other than Max. I don't want to totally disable the sound just limit how loud it gets when they turn it up. Thanks.
