Sound output asleep after about 20 - 30 minutes
  1. Posts : 3
    Windows 7 64 bits
    I read a lot about sound and the pc getting asleep. However my problem can not be found. Hope anyone of you recognize my problem and could be of any help:
    The pc is set up to NON-Energiesave. THis means I have set up all possible components to keep alive, not sleep.
    For my flightsimulator, I have setup several sound systems. These soundsystems must all be standby for immediate sound. E.g. call outs in a landingsituation. When the sound has to respons, I noticed that the sound that has to start up is missing about 1 second of the sound. I have looked around for hours also in the Bios. I cant find any sound related functions that cause it to go a sleep.
    So does anyone can tell me where I have to look or check to keep de soundoutput ALWAYS to ON
    Thank you very much. Hope this will have a solution.
    Best regards,
    Ed
    Does this happen with ANY sound from the PC or ONLY with the Flight Simulator program?
  3. Posts : 3
    Windows 7 64 bits
    Hi Firebird,
    Thanks for your fast reply!
    Ehmm have not tested that. Will investigate it today.
    Thanks and regards,
    Ed
  4. Posts : 3
    Windows 7 64 bits
    Hi
    It seems to be a behaviour of the onboard sound. What I have done now is having an enpty made wav file, continuous playing. Until now, this solve the problem it seems.
    Thanks and regards,
    Ed
