Windows 7: All system sounds are the same
03 Jan 2014   #1
pjd
Win 7 Professional 64bit
No matter what sound scheme I choose all system sounds are a low frequency click.
If I open a wav file and select play from the context menu I hear what I would expect, but when I apply that wav file (e.g. a chiming bell) to say System beep - all I hear is the click!
Other programs - like my PIM can use the same wav files and produce the expected sound - its only Windows that is stuck on this barely audible click for everything.
03 Jan 2014   #2
carwiz
Windows 7 Pro-x64
Perhaps imageres.dll is corrupt. Try running SFC /scannow from an elevated command prompt and check the console for messages.
04 Jan 2014   #3
pjd
SFC found nothing - but I found part of the problem - I had system sounds set off in Volume Control mixer (slider all the way to the bottom)
So... back to the actual problem
Had to buy a new keyboard in a hurry - the old one decide the Alt keys were sleep buttons Silly me said - okay, so lets get a wireless one.
The wireless one doesn't have any LEDs so I went to Control Panel\Ease of Access\Ease of Access Center\Make the keyboard easier to use and ticked the Turn on Toggle Keys boxes - and all I get is this barely audible tone.
So the real question is - can I change the 'tone' that's played when I press Caps, Num or Scroll Lock, to something I can hear above ambient noise ?
pjd
04 Jan 2014   #4
pjd
Found a gadget called Toggler that allows me to set sound, also displays indicators in tray
It'll do
pjd
System Sounds are gone!
Hello, suddenly I find that my system sounds are gone! :confused: I can hear audio from videogames, mp3 and youtube, but I lost the login sound, the usb insert/removal sound and so on! I don't have a working restore point and I tried to go to Mixer-> Audio -> Sounds -> Predefined and click Play...
Some System Sounds Won't Play
My Windows 7 computer won't play most sounds when an event occurs. I've already gone into the Sound window from Control Panel, and the sounds still won't play. The following program events DO play a sound : default beep, device connect, device disconnect, device failed to connect, empty recycle...
System sounds are very low
Hi, I've been having problems with sound issues in this 3 month old system since day one and have searched here for days for a possible solution. I've tried all of the suggestions to no avail. My system sounds (on the volume mixer bar) never go higher than 10-15%. Media Player seems OK but not...
Windows System Sounds
I want to change the system sound that plays when my pc completes formatting a USB drive. How do I do this?
System sounds are not loud enough
My System Sounds are not loud enough and certainly noy as loud as in any previous Microsoft OS. Can this be "fixed?" :(
Mac OSX System Sounds
Anyone know how I can get the Mac OSX system sounds installed into Windows 7? I can't seem to find them on the internet, only done a bit of browsing but if someone can point me in the right direction I'd be very grateful. Thanks :cool:
Themes and Styles
