Windows 7: Default Audio Device keeps switching using Razer Virtual Surround.
05 Jan 2014   #1
TyMiles2012
Windows 8.1 x64
Hey, everyone! This is kind of hard to explain so I have a YouTube video below, but what I'm trying to do is to lock the default the Razer Virtual Surround device as the default sound device, but I can't seem to make that happen. I've looked everywhere for the past few hours and I can't find anything. It's driving me crazy, does anybody know what I can do to fix it?
The first part, before I restart the app, the devices window on Razer's panel was messed up, but that always happens when I restart my PC. When I closed it and started it back up after changing compatibilities, it fixed itself, and all I need to do right now as I'm typing this is to keep the default device as Razer's virtual surround. Thank you!
EDIT: Okay, the YouTube thing isn't working, so here's the link itself.
http://www.youtube.com/watch?v=_mzITnqbS6s
05 Jan 2014   #2
fireberd
Unless the Razer has some way of always (automatically) installing itself as the default audio playback device, I don't think you can do what you want. The default for Windows is the "Speakers" (sound card) or if you have HDMI when an HDMI cable is plugged into the PC it will default to HDMI as the default playback device.
06 Jan 2014   #3
TyMiles2012
Windows 8.1 x64
I'm not sure what happened, but it seems like it fixed itself, but I had to restart my PC and it messed up again. I guess it just... Happens. *shrugs*
Prevent W7 Switching Audio Device When Connecting/Disconnecting USB De
Hi, Everytime I connect or disconnect a USB device my default audio device changes to a different device.. anyway to prevent disable this from happening.. I use USB mostly to charge my smartphone and only occasionally to transfer files but it is an annoyance as not only I have to change the...
Virtual Playback Audio Device - How?
Hello! I'm wondering how to create a virtual audio device for Windows 7. As in, a virtual audio device that shows up here: 273be50f07df62c03b32e53634c529ea.png Why? Mostly because I'd like to be able to live stream while talking to people on Skype who are also watching the stream without it echoing...
Razer Surround Sound
Looked interesting, thought I would share to see if any one wanted to give it a try. Razer Surround - 7.1 Gaming Surround Sound - Razer United States
Gaming
Keyboard stopped working after installing Razer surround.
i recently installed a razer program and my friends USB drivers onto my computer, when they were finished i needed to reboot my computer so i did, once it was done i could use my keyboard in the bios setup and such but i cannot use it to login to windows. i tried booting in safe mode, still no...
Hardware & Devices
audio device isn't set as default, can't make it default
Hi all, Windows 7 Home Premium x64 on HP-DM1-4050us laptop, disabled a couple of unneeded services, now headphones not working, no idea which service caused this but I didn't touch either of the two required audio services (Windows Audio, Windows Audio Endpoint Builder). Audio now plays fine...
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
