Windows 7: i have a dual monitor display and want sound from both monitors
07 Jan 2014   #1
djzontheball
I have 2 27" Samsung Syncmaster s27b550 monitors which are connected to my Nvidia Geforce GTX650 TI via HDMI and VGA. both screens have speakers. i also have an inbuilt sound card on my Motherboard.
Sound comes out of my Graphics accelerator through the HDMI Cable to the monitor on my left and if i plug a 3.5mm stereo cable from my on board sound card to the audio in jack on my 2nd monitor i don't get anything.
what i am trying to achieve is to setup up the monitor on my left as the left channel and the monitor on my right as the right channel so it balances the sound between the two monitors. Can i blend the two sound outputs like they are 1 and use each output as a single channel.
07 Jan 2014   #2
fireberd
I don't think you can do what you want, with the setup you have. First, Windows only allows one "default" audio playback device and with HDMI it defaults to the HDMI audio. Thus the PC audio (speakers) do not work.
I don't know if an external device would split the HDMI audio so you could do what you want. That looks like the option if something like that is available.
In display settings, multiple monitors are identified in one monitor
Hi I have a Sony VAIO VPCSB3S9E/B Windows 7 64 bit. It has a 1366 x 768 display. It also has the stamina/speed button switch which I had almost permanently on Stamina. Today, however, I switched to Speed and the resolution is odd. It's stuck at 1078x768. On the resolution screen, there are two...
Graphic Cards
Cannot change main display--dual monitors
I have two monitors. The graphics card has VGA and DVI ports. The VGA monitor has much larger screen & I want that to be the main display. Currently the smaller (DVI) display is main display, i.e, Number 1. I want the larger VGA display to be the main display, i.e., to be Number 1. Both monitors...
Music, Pictures & Video
Can't get dual monitor wallpaper to span both monitors
I don't know if I'm doing something wrong, but I have a wallpaper that is 3200x1200 resolution, and my two monitors are 1600x1200 each. The wallpaper will only mirror on both screens instead of half being on one screen and half being on the other... How can I get this to work properly?
Customization
Dual Monitors, Monitor two black
Hi guys ok so I have two screens set up one of them is my usual display. A acer x223HQ PC monitor the other is a Samsung TV There are both connected into the graphics card and not the motherboard. but yet screen two is black. The rez for both screens are set too 1440x900 the monitor can go...
Hardware & Devices
Dual Monitors, HDMI monitor doesn't display BIOS
My old monitor has problems turning on, I can leave it on for 30hrs before it decides to display a picture, or I can manipulate it by unplugging the DVI cable from the back, but sometimes even that takes a few tries. It's off warranty and for reference it's a Samsung SyncMaster 226BW. So I...
Graphic Cards
Dual Monitors: Folders Appear On Wrong Monitor
Hi I have a strange problem, certain programs always open on the 2nd monitor which i dont always have switched on. For example I double click the program to run and it always opens on the 2nd monitor even if I drag it to my main monitor it always defaults back to monitor 2. Also why when I run...
General Discussion
