Windows 7: Problem with my sound, got delayed 0.5s randomly
09 Jan 2014   #1
Redsiamesecat
this happened 1 week ago, and ive been using my laptop for a year...
its got delay/lag for 0.5s from any sound (music player, video, sound from game too..)
my laptop is asus N46VZ , and i currently reinstalling windows 1 week ago..
this never happenend before, is it driver or hardware that makes it like this ???
need solution
sorry for my bad english
09 Jan 2014   #2
fireberd
Windows 7/10 64 bit
Do you have the correct sound driver? The ASUS supplied is the preferred driver.
10 Jan 2014   #3
Redsiamesecat
Yes, I hv correct driver, I downloaded it from asus website, I dont know what causes it..
10 Jan 2014   #4
fireberd
Windows 7/10 64 bit
Since this apparently has happened since the reinstall, go back over the installation and check that you did not miss any drivers during the installation.
10 Jan 2014   #5
Redsiamesecat
what do u mean , go back over the installation ?? does it mean i hv to reinstall my windows again ??
all of my driver downloaded from asus website and i hv already check,i didnt miss any driver, cause installed them one by one...
and i tried to look at event viewer when the problem occurs, but i cant found error or anything in the same time when problem occurs....
thanks
11 Jan 2014   #6
fireberd
Windows 7/10 64 bit
No, I was just asking you to check your installation to make sure you did not miss anything.
Sound Randomly stops
Hi people. Having an annoying issue that's started occurring the last couple days. As the title says my sound is dropping out at random times. I've noticed it has occurred when my computer stops performing a task with sound. It has stopped after playing a game, watching a movie and listening to...
Sound randomly Changes
Since i i started using my new MSI (TwinFrozr Series) GTX 760 OC , my sound fluxuates up and down randomly sometimes its so lil people in my house think its just me then theres times watching a twitch cast it almost goes total muted. I never had this w/ my XFX Radeon HD5750 (Yes i use HDMI Out for...
PC Crash to black screen with delayed sound looping no BSOD message
Hi, I've had computer problems for the past 3 months although I thought I had fixed it until just tonight I've tried to play Counter-Strike : Global Offensive and within 10minutes of gameplay the pc crashes to a black screen and I can still hear people on ventrilo for a couple of seconds before...
BSOD Help and Support
No sound, Realtek sound inputs assigned randomly
The realtek audio managers shows that the front two inputs, front mic and headphones, are always plugged in when there is nothing in them at all. When I plug in my speakers to the back green input for sound it inputs both the green one, front speakers out, and the blue input, line in. Now I get...
Delayed sound on startup
I am experiencing a delay on the windows sound when my computer boots up. The computer starts and the screen appears but the typical windows start-up sound is delayed by about 5 seconds. I know that this can be adjusted. Does anyone have any ideas where it is located please? Thanks in advance. ...
Sound randomly turns off
For some reason my sound either mutes or is lowered when I play team fortress 2. I thought this was just a game problem, but now it randomly goes off for no reason at all. I tried fiddling with the device properties and that just makes the sound go out as well. My built-in mic isn't working either....
