Windows 7: Using two audio devices the same time...
10 Jan 2014   #1
marios1441
Windows 7 Ultimate 64-bit
How can I use both my Usb headset and the 3.5mm phono jack speakers playing at the same time and even two microphones one that is USB and other that is 3.5mm jack? How about using two 3.5mm jack devices?
11 Jan 2014   #2
fireberd
Exactly what do you need both for? If Windows sets the USB headset as the Default Playback device, you can't use the PC's speakers as Windows will only allow one default playback device.
11 Jan 2014   #3
marios1441
I don't want to unplug and plug when i want to use my small headset with microphone for Skype that is 3.5mm (that has minimum noise) or the large USB headset with microphone for music everytime.
11 Jan 2014   #4
marios1441
Is there is a program for doing this?
11 Jan 2014   #5
fireberd
No program that I know of. You may get by with just changing the default playback device in the Sound Panel (Playback) section from the Headset to the "Speakers" (You PC's sound card).
Also, in the Sound Panel/Recording section, set the "Stereo Mix" (may be called System Mixer) as the default Recording device. Then whatever device is being used you should hear.
11 Jan 2014   #6
marios1441
The small 3.5mm headset i need it for Skype talking as because is very small it produces sound with no noise and the big USB headset for amplified music. But i hear no noise outside Skype. It also has noise cancellation microphone. I tried the Stereo Mix for recording devices and the 3.5mm microphones work but not the USB microphone of the USB Headset. Why is that? Can i use Stereo Mix for playback devices and also USB microphone? If yes then how? I can't get Stereo Mix appear for playback devices in the Windows Audio configuration window.
11 Jan 2014   #7
marios1441
I can't hear anything playing with Stereo Mix from the USB headset.
11 Jan 2014   #8
marios1441
Also the USB Headset's microphone that both connected with only one USB Plug is not working with Stereo Mix.
11 Jan 2014   #9
fireberd
Then you will not be able to use Stereo Mix. USB is "digital" and bypasses some or all of the sound card and probably why the stereo mix does not work.
Audio USB Devices showing under Other Devices in Device Manager
Hi! I have two USB audio devices that I cannot seem to properly install drivers for. Focusrite Scarlett 2i2 & KORG MicroKONTROL I am in communication with both product tech support teams but so far they have not offered a successful solution. As the same issue is occurring with multiple...
Hardware & Devices
Audio Only out of one channel (multiple headsets and audio devices)
I have three audio devices on my pc (ATI HDMI, Via HD onboard and steelseries usb soundcard) and through all devices I only get audio out of the left channel. I have tried two pairs on headphones and my tv speakers all with the same results. I have looked at all the balancing end everything is set...
Audio configuration no audio output devices?
my computer's sound has stopped. I have searched through lots of websites looking for help. I first noticed this problem when I tried to open iTunes and it came up with the message 'iTunes has detected a problem with your audio configuration. Audio/video playback may not operate properly'. I also...
Realtek HD Audio/Motherboard Not recognizing any Audio Devices.
Hello, I'm gonna try and lay out my problem very simply, and then tell you what I have tried/done. PROBLEM: When I plug in Headphones, I can not hear anything, and in the playback devices, nothing is shown to be plugged in. This goes the same for my other audio device which is a bose sound...
Can I Listen To Audio On Two Devices At The Same Time?
so when i had xp i could launch WMP with my speakers and change to output to my headphones. the music would play on the speakers and i could play a game on my headphones at the same time. now it changes the moment i switch default audio outputs.
two audio devices at the same time
hi together.. i have three audio devices on my system. a Creative SB X-Fi, a Logitech Z-10 USB Speaker and a Trekstor SoundBox USB Speaker (wireless). I would like to use the Logitech Z-10 USB Speaker or the Creative SB X-Fi and the Trekstor SoundBox USB Speaker (wireless) at the same time...
