Stereo Mix Via High Definition not picking up sound.
  1. Posts : 23
    Windows 7 64 bit
    Using an analog stereo connection cable, a main USB connector and (Headphone) via high definition as default playback device, I want to use Stereo mix (Which is enabled and supposedly working, not muted and up to date) to play sounds in Skype calls. I checked out the recording devices and the green bars for stereo mix are not moving when sound is playing.
    My friend on the other hand has the same head set using the same analog stereo cable and playback settings, but is able to play sounds in the Skype call.
    Doing some research on that motherboard, I see it has RealTek HD Audio.
    I'm not sure exactly what you are hooking up. "Using an analog stereo connection cable, a main USB connector and (Headphone)". Can you explain a little more on exactly what you have?
    With a mix of analog conections and USB it can be a problem (I have a recording studio and use both).
  3. Posts : 23
    Windows 7 64 bit
    Its a headphone and it uses an analog stereo connection, put into the green outlet for sound in the front side of the computer. Via HD is my sound and recording software.
    The USB is used to power the headset. Headphone Via High Definition is my default playback device.
    Either way, weather I use a speaker, ear plugs or a different headset, stereo mix doesn't pick up noise.
  4. Posts : 8,135
    This is what the ASUS site shows for the motherboard you have listed in the My System Specs. Is the problem you are having with a different PC?
    Realtek® ALC887 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
    Audio Feature :
    - ASUS Noise Filter
    - Optical S/PDIF out port(s) at back panel
    http://www.asus.com/Motherboards/M5A...specifications
  5. Posts : 23
    Windows 7 64 bit
    The computer that has the problem is here
    Desktops - Essentio CM1630
    I believe that the 61-MIBBJ5-01 is it's motherboard
  6. Posts : 8,135
    I see the ASUS specs but it doesn't name what the sound chip is.
    However, go to the Device Manager, RIGHT click on the entry for the sound device to highlight it and then LEFT click "uninstall". DO NOT check the option to uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound,. This usually fixes any Windows sound corruptions and if lucky will fix yours.
  7. Posts : 23
    Windows 7 64 bit
    Wow! Thanks, that seemed to have fixed the problem.
  8. Posts : 8,135
    Great. Glad I could help. The Uninstall procedure fixes a lot of flakey problems. Its one of my "standard fix" procedures.
