Stereo Mix Via High Definition not picking up sound.
Using an analog stereo connection cable, a main USB connector and (Headphone) via high definition as default playback device, I want to use Stereo mix (Which is enabled and supposedly working, not muted and up to date) to play sounds in Skype calls. I checked out the recording devices and the green bars for stereo mix are not moving when sound is playing.
My friend on the other hand has the same head set using the same analog stereo cable and playback settings, but is able to play sounds in the Skype call.
