Windows 7: No sound when headset is plugged in
14 Jan 2014   #1
randomzerg
Hello all,
I am on laptop using Windows 7 home premium 64bit. There is sound when nothing is plugged into the audio jack, but when something is plugged, there is no sound.
I am using also Kubuntu on the same laptop, and the sound works perfectly even when a headset is plugged in the audio jack. So apparently the problem is with the driver.
Also the headset does not appear in my Playback devices at all (neither as disabled/disconnected) (although a notification comes up when I plug a headset in saying that something was plugged into it).
I've been searching for this problem for a long time, and could not find a solution for it.
I tried downloading the driver from dell.com, I even tried re-installing windows all along. Nothing works.
After using windows for the first time after re-installing it, the headset worked properly (even without the official driver installed), but it stopped working upon a restart, which is when I tried installing the driver from dell.com which didn't work.
Please help, this problem is driving me crazy..!
Thanks a lot,
rand
14 Jan 2014   #2
fireberd
If you mean there is no speaker sound when a headset is plugged in, that is the normal configuration. Some PC sound systems have an option to either mute or not mute the speakers when a headset is plugged in. Depending on what sound you have and the control panel for it that may or may not be an option.
There is a Dell "N"5030 and an "M"5030. Which do you have?
15 Jan 2014   #3
randomzerg
Speaker works fine, but when i plug in a headset, there will be no voice in the headset (headset works and the audio jack works too since they both work Kubuntu)
The headset doesn't even appear in the playback devices.
Sorry for not explaining it right. (first time trying out the forums)
Thanks for your quick reply!
15 Jan 2014   #4
fireberd
There are two different sound drivers listed on the Dell downloads, depending on whether you have an "N"5030 or "M"5030. Are you sure you downloaded the correct driver?
15 Jan 2014   #5
randomzerg
I downloaded the driver using the Dell Service Tag, which is supposed to be unique for my laptop. I also tried downloading the Dell software that detects which drivers I should take. Both failed.
My laptop is Dell Inspiron N5030
15 Jan 2014   #6
Collin2011
Windows 7 Ultimate x64 / Windows 8.1 Pro x64
I don't know a thing about linux but the concept should be the same. Have you tried setting your speakers as the default audio device?
15 Jan 2014   #7
fireberd
Here is the link directly to the sound driver download for the N5030. Note the instructions for downloading and installing.
Click on "Download File" DO NOT use the Add to My Download List as the Dell Download Manager doesn't always work properly.
Driver Details | Dell US
Collin2011, he has stated that the speaker works OK, so the "Speakers" would be set as the default playback device.
15 Jan 2014   #8
Collin2011
Oops I read that wrong my apologies. Just do what fireberd has instructed.
15 Jan 2014   #9
randomzerg
Alright, this is really weird.
So I downloaded the driver you told me, which was the same name as the driver installed, but still i proceeded with it (maybe its a better version).
So it told me if I want to remove the current driver, reboot, then install this one. so I did so.
Now for the weird part; after removing the driver and rebooting, windows found and installed a driver on its own, i tested if sound comes out from the headphones, and yes it did! But still the headphones did not appear in the playback devices.(neither does a notification come up when I plug in the headphones)
Now I installed the driver you posted, rebooted, and again, sound came out from headphones and all is good. Except headphones still do not appear in the playback devices. (but a notification comes up now when I plug it in)
I am afraid that this might stop working after some time (just like I did when i re-installed Windows)
Is it normal for the headphones not to appear in the playback devices? Is there a way to fix it?
Thanks for all your help guys!
15 Jan 2014   #10
fireberd
I have RealTek on my desktop PC. When I plug in the Headphones I get a notice they were plugged in, but they DO NOT show up on the Sound/Playback panel. Just my "Speakers" and options for digital (S/PDIF).
Search this Thread:
Advanced Search
My headset has low volume when plugged in speakers
Hi, I bought a new headset today, identical to that of my sister, which is very loud ( in a good way). So, when I plugged the set to my speakers I was disappointed because it was lower than that of my sister's. But then I thought to plug it to front green panel of the unit and boom!!! the sound was...
My sound is going through PC instead of the MIC with headset
So i've been browsing forums for a while now and can't find out what's going on. I have a sound card with Realtek HD Audio. Recently, I connected a PCIM cord to my motherboard so I can have sound on an HDTV, which works fine. SINCE then, this problem started. The front ports for MIC and sound don't...
Everything is plugged in except there is no sound comming
Hey Problem: Everything is plugged in correctly and i receive no sound from my speaker or headphones. The back panel jack is pissing me off . When i plug the speaker jack and if all goes well , sound is sent and played through speaker ... BUT if i miss the angle, rotation or whatever it is that...
Microsft headset not being detected when plugged in
Hello, I have a Microsoft headset which I have been using fine until today. When I attempted to use it today the computer shows it as unplugged. The interesting thing is that when i unplug it it shows as plugged in :s Any help on solving this would be appreciated.
No sound after headphones plugged in
Hey I bought a 2230s HP laptop less than a month ago. I noticed the phono-stick was really, really tight. But my headphones could still go in. But a few days ago, when I had had my headphones plugged in, my speaker didn't work after that. Or there came no sound :) I restarted my computer and...
Static background noises with my headset plugged in to sound card
Hey guy, I have an annoying problem with my Steelseries 7H headset. When I connect my headset to my sound card via front panel, I hear static background noises like when I scroll the mouse, I can actually hear it in my headset speakers, its very low and staticy but I can hear it, when I turn up all...
