Fraps does not record audio
  1. ECH
    Win7
    I am not sure what's going on but after a few reinstalls of fraps I am not able to fix the problem. For whatever reason Fraps will no longer record a video clip with audio. I recall seeing "What U hear" in the Volume Control Options" but it doesn't show up any more. Can anyone confirm where "what u hear" is located if Fraps is working properly for you? Also, how does one solve this problem?
    Note:
    The Sound Device from Frap's Movie tab reads: Vista Direct Stream. Is this what it's suppose to read for windows 7?
  2. ECH
    Win7
    Update
    Ok, so far it's BF2 v1.50 that is doing this. I tried other games and no problems with audio/video reproduction.
  3. Posts : 1
    Windows 7 Ultimate 32 bit Build 7100
    What kind of sound card do you have? You may need to change your default recording device while recording with fraps.
  4. ECH
    Win7
    X-Fi card. I've checked those settings and they are where they are suppose to be. Unless there is some other specific feature. I think that aspect is ok.
    I do have "What U Hear" but it's currently unavailable. However, when I go to properties and check it reads Device usage: Use this Device (enabled).
  5. ECH
    Win7
    Hmm, I wonder if "what u hear" is part of some DRM feature? If so where is the actual file? I like to have a word with it...
  6. ECH
    Win7
    Ok, It appears that "what u hear" is DRM controlled in one form or another. There is a program that does get it working but I am not sure if discussing it further is permitted on this forum. Is there a mod that can answer this?
  7. ECH
    Win7
    any advise?
