Windows 7: Front Panel Mic not working with Sound Blaster Z
31 Jan 2014   #11
joebots
Windows 7 x64 Ultimate SP1
Quote   Quote: Originally Posted by NoN View Post
Just one tip maybe...when you plug from back to front panel and versa , Sound Blaster engine doesn't switch the mic automatically. You have to switch it manually from rear mic to front mic in the "crystal voice" panel.
I tried this but I could never get front mic to appear in the crystal voice panel no matter what I did, or in the Windows 7 recording properties. I looked for hidden or disabled recording devices as well. Nada.
PS: Better disable HD audio panel in bios settings, but seems obvious if you do plug the case HD Audio cable onto the Pci-e card..
I did this even before I installed the card.
There were other peculiar things going on, too. Sometimes coming out of sleep mode Windows 7 would recognize the card as a Recon3D PCIe. I'd have to reboot when this happened to get sound back. I also got a few Blue Screens, which never happened before. It could be just be compatibility problems with my motherboard, the OS, or some kind of driver issue. I gave up trying to get it working and returned it for a refund. It's a shame because it put out really nice sound.
Thanks for your reply.
01 Feb 2014   #12
NoN
Quote   Quote: Originally Posted by joebots View Post
Its a shame you couldn't make it on your Motherboard and system based OS.
The Sound Blaster Z just working like a charm on mine with latest drivers. No cracks & poppy noises coming out my sound system 5.1 (only one pop coming from a light commutator in the house, badly isolated that i can hear out the speakers).
Otherwise great sound for watching movies, musics, and fear myself on some games.
03 Jun 2014   #13
robort1138
Windows 7 Professional 32bit
I had two computers both running Sound Blaster2 ZS (SB0350), one was the platinum. Both setups worked fine with XP but forced out of XP (thanks Microsoft) went with Win7. Neither sound card was functional using either installation disc and drivers that came with them. Great sound cards but a generation before Win7 so the drivers just don't work.
Googling, one discovers the Creative Labs site offers updated driver downloads. Problem is, Creative Labs at this point sidesteps escaping all responsibility, because these are third party drivers. To download them you must navigate through the trial licensing agreement (Ireland) which mentions possible unspecified charges for using this software may (or may not) follow in the (unspecified) future. Furthermore, the agreement warns that avoiding adhering to the agreement guidelines could result with incurring "serious damage to your computer system." I wanted my sound systems working so I tried going along with it. Upon installing the software my speakers now worked great, but I noticed some of my folders were not functioning normally. I decided to uninstall and delete some folders the result of which was "NOT ALLOWED." I now get the occasional BSOD, especially recovering from sleep mode. These third party driver downloads corrupted my clean install. I haven't resolved this yet, although I have begun researching the BSOD issue.
Initially, it seemed I might do well to perform another clean install and get rid of the Sound Blaster products.
I read a PROFESSIONAL comparison review and subsequently purchased a ASUS Xonar Essence ST sound card with an ASUS H6 7.1 extension card to go with it. Then I discovered via USER reviews that they were having all kinds of problems with the drivers ASUS provides for Windows 7.
So many problems trying to use a broad range of peripherals (graphics, sound, etc.) with Windows 7.
As operating systems are released relatively frequently, apparently no one wants to invest time and money writing software for older products (they of course instead prefer to sell you new stuff) and the OS will be here today and gone tomorrow.
I will, little doubt, eventually do a new clean install but first I want to see where researching the BSOD leads. I would suggest (to be safe) use only current products that list on packaging they're compatible for your configuration. Don't totally rely on "after the fact" contrived driver updates that may not function.
A few Creative Sound Blaster Z problems. (Sleep Mode, Front Ports)
I have a few issues with my Sound Blaster Z card... The first is that when my computer wakes up from sleep mode the sound stops functioning. In Foobar2000 I get this error message. Unrecoverable playback error: A device attached to the system is not functioning. (0x8007001F) I can't get...
No sound in front panel jack
Hi, I recently upgraded from WXP to Win7 and ever since, I was not able to get any audio coming through my headphone which is plugged to the speaker port on the front panel of the PC. Speakers connected to the rear port works fine though. Can someone help?
No sound in Front Panel Jack
I had this problem since i installed Windows 7 yesterday and my speakers in the back of my computer work fine, but just i cant put my headphones in the front panel. I saw several topics on here about it, but i read them and couldn't find a solution. I tried other audio codecs, i tried to Install...
No sound from front panel jacks
New rig with GA-h55m-usb3 mobo with Win 7/32 pro SP1 - back panel sound fine. but trying original front panel jacks (AC97), and Silverstone fp94s jacks (HD or AC97) nothing. HD recognition should be automatic! Audio is integrated on board Realtek, driver r2.49-6121. I have upgraded the bios and...
mic not working on front panel
Hi I bought my wife a new pc as the old one was a single processor and very slow. It has 2 issues. The new one seemed straight forward, quad core much faster but two issues are annoying enough to make my wife not want it. 1. The front panel seems to be wired differently to the old pc - my...
sound/front panel ports
After my build, firs build btw, I have front panel mic/headphone ports. Also on my AC powered Altec Lansing speakers there is a headphone port. If I plug in my headphones into speaker port it mutes speaker and sound comes through headphones. When I plug in headphones into front paned ports I get...
