Windows 7: AC 97 front audio cables on this mb front audio? msi ms-7548
23 Jan 2014   #1
sdowney717
msi ms-7548
Motherboard Specifications, MSI MS-7548 (Aspen) | HP® Support
this is a cable i have
plugging in for a test wont short the board?
I am interested if you can have front audio and spdiff output sound.
HP says ---> One 9-pin audio header for headphone-out and microphone-in (yellow, Vista capable, requires matching front audio jack module)
also HP says ---> "Supports one S/PDIF digital connection"
the board has an internal and external spdif, so what is HP saying?
Quote:
Integrated Realtek ALC888S Audio
*Integrated audio is not available if a sound card is installed.
Audio CODEC: Realtek ALC888S
High Definition 8 channel audio
shows the external spdif #2 rca jack which I use hooked up to a sony receiver.
23 Jan 2014   #2
fireberd
An AC97 connection will work in place of an HD Audio connection to the motherboard sound connection. The AC 97 doesn't support some jack sensing that the HD Audio does.
It should work OK to test if you can get front panel audio and S/PDIF at the same time.
24 Jan 2014   #3
sdowney717
I plugged it in and get nothing at all, no sound from it and windows playback and record devices do not show it anywhere.
24 Jan 2014   #4
fireberd
Did you plug it in correctly? As noted, the only difference between AC97 and HD Audio connection is the AC97 does not have some jack sensing that HD Audio has.
24 Jan 2014   #5
sdowney717
the plug going to the MB?
It is keyed and can go no other way than the way it goes.
Got zilch, as if nothing was plugged in.
Maybe realtek chip just knows something is wrong with it.
HD audio does have a sense pin.
24 Jan 2014   #6
sdowney717
I do have my sound set to digital audio playback, would that be why no sound from the front audio?
24 Jan 2014   #7
fireberd
Yes. Sound has to be set to "Speakers" to get analog audio (what is needed for front panel).
24 Jan 2014   #8
sdowney717
Ok,
I dont even get a speaker option to enable unless I actually plug the HDTV into the back speaker port.
If this was a true HD audio jack, would it be detected as being able to be enabled?
24 Jan 2014   #9
fireberd
If you have an HDMI cable connected, the PC's sound card is not used and there is no output. As that is what you wanted to test, at least what I gather from your posts, this confirms that you can't get both.
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Front I/O Audio Jack not working.
Hello, Last month I built my own computer. I am having a problem with my Front I/O audio jacks. - Headset is Beats by Dr. Dre Solo HD - I have went into BIOS and enabled my Front I/O - My front I/O is properly connected to my Motherboard - My driver is Realtek HD R267 (Newest driver)
Need help with Front Panel HD Audio
I have had this problem for months and I have never been able to solve it. Bios is set for HD Audio. When I connect the front panel hd audio plug from my Lian-Li A77 case into the Asus Rampage II Extreme Supreme FX mini sound card the system will boot up normally. Then when I plug in the...
AC'97 and HD audio front panel layouts
This shows the difference between the AC'97 and HD audio front panels. The main reason for the difference is to do with speaker assignment. With the older AC'97 system, only a single pair of stereo speakers was supported. These could be switched on and off by a standard switching stereo...
help me with the front audio panel :(
hey guys! i'm new here, i just installed windows 7 yesterday, and i having a problem with my front audio pane both headphone and mic are not responding when i plug it in .i had Xp before, and the front panel worked without any problems, but now i can't get it working... tried the , newest driver,...
