Windows 7: Dolby surround of my sound card doesn't work properly
28 Jan 2014   #1
Windows 7 Home Premium 32bit
I can't hear a proper dolby surround with my headphones. I think the reason for this is that the dolby settings of my Asus Xonar Essence STX sound card and Windows 7 are not "synchronized". I just watched a Gears Of War 2 walkthrough video, and weapon fire, explosions and talking, that came from the sides, back or far away, were very low or not audible at all.
OS: Windows 7 32-bit
How can I set this correctly?
TIA
30 Jan 2014   #2
Windows 7 ultimate 64-bit
Well; you should be able to hopefully adjust that in the audio properties/settings by right clicking the speaker icon and selecting the sound card and if it is surround like you say; then there should be settings somewhere in there to adjust that. Also, if your sound card came with software like mine did; you might be able to adjust the settings using that as well. I cant say for certain 100% what settings etc. because i dont have the same sound card as you do. Hope this helps ya some. If not, post back and we can go from there.
Similar help and support threads for2: Dolby surround of my sound card doesn't work properly
5.1 surround doesn't work properly in all apps . Sound & Audio
Acer 8930G (5.1 Dolby cinematic surround) Sound & Audio
Windows detects surround sound, but music doesn't use Sound & Audio
no sound "Titanic" dvd - dolby surround sound?? Sound & Audio
AC-97 SPDIF output, just linear no Dolby surround Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
