Windows 7: Dolby surround of my sound card doesn't work properly
28 Jan 2014   #1
rfe777
Windows 7 Home Premium 64 bit
I can't hear a proper dolby surround with my headphones. I think the reason for this is that the dolby settings of my Asus Xonar Essence STX sound card and Windows 7 are not "synchronized". I just watched a Gears Of War 2 walkthrough video, and weapon fire, explosions and talking, that came from the sides, back or far away, were very low or not audible at all.
OS: Windows 7 32-bit
How can I set this correctly?
TIA
30 Jan 2014   #2
matts6887
Windows 7 ultimate 64-bit
Well; you should be able to hopefully adjust that in the audio properties/settings by right clicking the speaker icon and selecting the sound card and if it is surround like you say; then there should be settings somewhere in there to adjust that. Also, if your sound card came with software like mine did; you might be able to adjust the settings using that as well. I cant say for certain 100% what settings etc. because i dont have the same sound card as you do. Hope this helps ya some. If not, post back and we can go from there.
Looking for new audio card to support surround sound
Hey all. I'm looking for a new audio card that can run a true 5.1 surround sound setup. I have the Logitech X-540 5.1 surround sound speakers. The mother board I have has the HD audio built in, but I dont think it can run a true 5.1 surround sound setup. It just seems they all play at the same tune...
5.1 surround doesn't work properly in all apps .
Hi. The strand thing that it's working perfectly in AIMP3 , but when I'm playing a movie in classic media player or YT video, only the center and right speakers are working . The others have this weeird , super low delayed sound , barely Noticeable . This is my motherboard , maybe I've...
Rocketfish 5.1 Surround Sound Card / Volume issues
Hello, I been using the Rocketfish 5.1 surround sound card for quite some time now, and just last month or so it just stoped working if I dont use the matrix mode all the speakers work. But I constantly have to turn the levels of each speaker up in the sound settings and when I do that it max's out...
Acer 8930G (5.1 Dolby cinematic surround)
Hi all. I have a problem here. I installed Windows 7 64x bit ultimate edition on my laptop. And i have a Dolby Home Theater 5.1 cinematic surround sound build in.It has 6 speakers in total and which one of them is the TUBA subwoofer. But the problem is windows 7 doesn't support it. I only get 2...
Windows detects surround sound, but music doesn't use
Windows detected my surround sound system just fine and I hear a noise from each speaker when I click the test button, but in WMP or another player it only plays from the two front speakers. I thought this was solved but apparently it's not. Any idea how I can fix it? It's onboard surround...
AC-97 SPDIF output, just linear no Dolby surround
First of all , hi to everyone, this is my first post in this forum and since i found no welcome threat, i just post the first part here :D so second is my somewhat awesome problem. I recently just switched to windows 7 on my pc. specs. Abit NF7-S rev. 2.0 AMD BArton 3000+ 2x 512 MB Ram
