Windows 7: HDTV audio device disabled, then vanished
29 Jan 2014   #1
Danhattan
I've been streaming from my Acer Aspire laptop to an LG HDTV for a couple years. No problems with either video or audio. Once I plug an HDMI cord from the laptop to the TV, the laptop sound output defaults to the TV speakers after the laptop makes a two-note sound indicating connection. Three nights ago, after done streaming, pulled the cord from the laptop, and didn't hear the sound. Using the laptop, no sound was issued from the laptop, so checked the speaker default through the speaker icon in the tray. It was still defaulting to the TV speakers. Should have just restarted the laptop right here.
Instead, right-clicked the TV speaker icon, chose Disable Device (thinking this is temporary), and the sound output defaulted back to the laptop's RealTek speakers. However, Disable Device equated to Delete Device as the laptop no longer defaults to the TV speakers through the HDMI connection, and the TV device no longer shows up as available in either Speaker Properties or the Device Manager.
How is this device/connection restored? Thanks in advance for any help. Daniel.
29 Jan 2014   #2
fireberd
You can try a System Restore (using an available restore date that is BEFORE you disabled the device).
If that does not fix it, reinstall the video driver (which should include the HDMI sound driver).
System Restore can be accessed from Start/Programs/Accessories/System Tools. System Restore will not delete any user data or e-mails.
Please fill in the "My System Specs". It helps use to try and help you.
29 Jan 2014   #3
Danhattan
System Specs
Fireberd,
Thanks for the reply. First, I've never done a system restore as I don't go recklessly surfing and also have Spybot up to date.
Second, I apologize in advance because when I first hit this forum, I did see the link to finding complete system specs and (oops) ignored it. How complete do the specs need to be? Not sure of the bit count on W7, but processor is Core I5, Aspire model is 5750, 4GB/500GB.
Now, call me nave, but it just doesn't seem like this problem should be so vexing. Disable doesn't mean Delete, so that audio device must still be on my computer just waiting to be Enabled, no?
Again, thank you. Daniel.
29 Jan 2014   #4
Danhattan
System specs, revisited
Fireberd,
After replying, saw link to system specs and did some checking. OS is W7 Home Premium, 64 bit, SP1. If more is necessary, let me know. Thanks again.
29 Jan 2014   #5
fireberd
System restore is not a complete reinstall. Just a "step back" to an earlier time.
System Restore is a feature in Microsoft Windows that allows the user to revert their computer's state to that of a previous point in time, which can be used to recover from system malfunctions or other problems. ...
http://en.wikipedia.org/wiki/System_Restore
30 Jan 2014   #6
carwiz
Windows 7 Pro-x64
Open Sounds and click on the Playback Tab. Move your mouse anywhere inside the box of devices and Right Click. Check the two boxes for Show Disabled Devices and Show Disconnected Devices. Does the speaker show now?
30 Jan 2014   #7
Danhattan
Carwiz,
First, thanks for your time. Second, I was really excited when I read your post. I'd been to that window, but it hadn't occurred to just right-click within the empty part of the window. Did so, and your screenshot is replicated.
That said, the HDTV device didn't reappear. At first. Dawned on me that since the laptop was on lap and not connected to the computer, the device wasn't available. Connected to the TV, and sure enough your advice was perfect. Audio restored. Really, really appreciate your time and knowledge. Seeing that others have looked at my post, hope you helped a lot of people.
Finally, in my opinion, you rock. Cheers. Daniel.
Audio Device is disabled/not installed
Hello, I'm new here and I have a problem I hope you all can help me with. OK, my audio was working fine until I decided to update the IDT High Definition audio driver. Bad mistake... Once I supposedly updated the audio driver, now my audio is not working and it has a red X on the speaker icon....
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
Help seting up Audio through HDMI to HDTV
My system specs are listed for my rig before I say anything that is what I am running ATM Current video card has an HDMI and with space limitations been trying to get my 40" Toshiba to work as a monitor. I been trying to get audio to the set and found the options in the Gforce control panel, but...
Audio device is disabled - no audio at all.
I'm on the verge of re-installing Windows. Spent the last 4 hours searching on here and other forums for a fix, but can't seem to find any. It started earlier today, I'd just installed Call of Duty: World at War off Steam, tried to launch it and it kept crashing. Tried a few things, but nothing...
How to identify disabled device in Device Manager
When I disable the network controller in Device Manager, the controller is disabled but nothing changes in Device Manager to identify the device as being disabled. When I used to do the same thing in Windows XP, the device icon turned yellow. Is there some setting to identify disabled devices...
Hardware & Devices
Audio Device Disabled (tried all normal approaches)
Hi there, well a while back my system (specs below) had a windows update when I went to bed, upon my return my PC booted up with no sound avaliable. i.e. in my task tray the speaker has a red X and displays "No Speakers or Headphones are plugged in" - they are definately plugged in. I did try to...
