Windows 7: Is it possible to script frequent changes to monitor/sound settings?
29 Jan 2014   #1
hb1547
Windows 7 Professional x64
I've got a desktop running Win 7 Professional.
On my actual desk I have two monitors, one that I use as my main one, and a second that I bring up when I could really use the extra display. I also have a set of basic speakers.
However I also hook this tower up to an HDTV, and use that as a the audio/video out regularly.
I'd like to set up some basic scripts for switching between these devices, without having to go through the settings myself.
Is this do-able, either natively in Windows or through some third-party program?
03 Feb 2014   #2
PatrickGSR94
I would like to know this, as well, specifically changing what output the sound goes to.
I currently have JBL Pebble speakers connected through USB, and also an HDMI cable from my video card to the TV, and an optical cable from the motherboard to my receiver.
Most of the time I just use the Pebble speakers for sound. But every now and then I want BIGGER sound in the living room and would like to send the sound to the surround sound amplifier. Also on some occasions I use the TV for viewing online content when my TV or Blu-Ray smart apps just won't get the job done.
I have a Harmony 650 remote that I use for the amp and TV to get them on the correct inputs for whether I just want sound from the PC, or both sound and video. But I then have to go into "Playback Devices" and change what output is the "default" to get the sound out of either the Pebble speakers, or my amp and surround sound speakers.
Is there not an easier way to accomplish this besides having to change the "default" setting every time?
Script To Turn Off Proxy Settings
I have a problem PC that I've scrubbed clean with everything from Combofix to Ccleaner to Malwarebytes anti-rootkit, to JRT, to ADW, to TDSS, to rkill and beyond. The only thing wrong with this PC is that, every few days the proxy settings are toggled on and I need to go turn them off. I can...
Network & Sharing
Help needed in creating a script to change certain Windows 7 settings
Morning, afternoon and or evening ladies and gentlemen. Glad to be a part of the forums. As the title of the thread implies, I would like some help in creating a script or scripts to change a few settings in windows instantaneously with a single keystroke, command or perhaps using specific...
General Discussion
Single Monitor shutdown script
Hi I have recently started using multiple monitors but due to my second monitor having a VGA connection it defaults to the primary display when starting up and it shows the bios and windows log on and only once windows has started will it revert back to my DVI primary display. My question is:...
Customization
BSOD playing games as well as frequent monitor blackout
Hi, Recently i have been getting BSOD while playing games and watching videos. Monitor blackout happens occasionally, with me having to restart the computer in order to get the screen back. I thought it might have been a software issue so i went and reinstalled the drivers, but to no avail. Im...
BSOD Help and Support
[Sound crackling ] VPN client messed up my sound settings
Hi folks, Recently I was setting up a VPN client (PacketIX), and the setup wizard suggested some Audio/Video Streaming "Optimization" tweaks. I didn't pay attention and confirmed. Since then, I often hear some crackling / popping noises. For instance, this systematically occurs when I...
Script to change power settings
Greetings, I am attempting to temporarily disable hibernate and make sure the monitor doesn't go off while I am running a script to complete system configuration. control powercfg.cpl -monitor-timeout-ac 30 control powercfg.cpl -monitor-timeout-dc 30 control powercfg.cpl /hibernate off
Performance & Maintenance
