Windows 7: Using a Graphic Equaliser With Realtek Audio?
30 Oct 2014   #11
jargraj
Win 7 Home Premium 64 bit
As requested.
The window on the right is what i get when i click on HD audio manager in control panel, the window on the left when I plug in headphones.
Sorry it took so long ive been busy all week.
30 Oct 2014   #12
dsperber
Quote   Quote: Originally Posted by jargraj View Post
As requested.
Did you intend to post a screenshot? Nothing shows. Please edit and try again.
01 Nov 2014   #13
jargraj
It shows for me when I click on the little image button, I can't figure how to embed an image in the post? It should function as a link to my dropbox
01 Nov 2014   #14
dsperber
As you can see from Chris Nicola's post #7 above (he, too, posted a Dropbox picture), if you just paste the dropbox URL for the JPG itself into your post, that will provide a usable link in your post that we can click on to see the image. Don't use the "insert image" button.
Normally, inserting an image and having it display in the post itself (as I have done is my own post above) is done by manually sandwiching the URL for the image between a "start image" and "end image" delimiter, i.e. "[ i m g ]" and "[ / i m g ]" (with the spaces removed). But this works for me because I use ImageShack as my web repository for photos that I share this way... I don't use Dropbox.
URL's from ImageShack work fine as the pasted contents for the "insert image" button (and then push the OK button) and that picture is inserted properly and visibly into the post, but Dropbox must not work the same way. Just paste the Dropbox URL for the JPG in your post, as Chris Nicola's done, and then we can click on the link ourselves to see the picture from Dropbox.
04 Nov 2014   #15
MourningStar
I too am not able to view the eq, only presets. See attached screenshot - How do I get it to display?
-thx
11 Nov 2014   #16
jargraj
14 Nov 2014   #17
MourningStar
09 Feb 2015   #18
jaspergap
I'm in the exact same situation as jargraj, and I think we even have the same laptop... This problem has been bothering me ever since I bought this laptop, and I never found a solution for it. I really hope somebody can give jargraj and me a solution for it, because it really sucks.
I'm sorry I might have resurrected the thread, but this is the first time I found a relevant thread for my problem.
I hope to see a solution real soon.
Thanks in advance
09 Feb 2015   #19
Chris Nicola
Windows 7 Ultimate 32 bit SP1
In Control Panel /Realtec HD audio Manager can you see the following screenshot? Click the equalizer icon (circled at the bottom) to make it appear.
https://www.dropbox.com/s/xhnq0w65kc...altec.JPG?dl=0
Kind Regards
Chris
10 Feb 2015   #20
jaspergap
No I don't even have 4 tabs for my speakers... I only have 2: speaker configuration and default format. ThaThat's the problem.. On my pc downstairs I do have the same window like in your screenshot, but my laptop does not
Realtek HD equaliser backup/restore
Hi everyone, i really need some help concerning my Realtek HD equaliser.. My computer crashed and i just installed a fresh version of Win7 ultimate x64 on my pc and i would like to know if its possible to get back my custom equaliser for Realtek HD sound manager!!! like is it saved somewhere in...
Backup and Restore
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
ASUS/Realtek, Latest Realtek versus default W7 Audio driver
I installed the Realtek HD audio driver from the ASUS download site (P8Z68-V Pro MB) and all was well until I installed an MSI 560TI video card and let it install the Nvidia HD Audio drivers. The problem I have been chasing ever since was the Realtek HD Audio Manager popping up after the system...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
