Windows 7: Using a Graphic Equaliser With Realtek Audio?
11 Feb 2015   #21
Chris Nicola
Windows 7 Ultimate 32 bit SP1
Are you sure you have the latest and correct Realtec driver for your system? It might be a problem with the system settings or the driver might be corrupted or be the wrong version. You might need to uninstall and reinstall the driver or try a different Realtec driver version.
Kind Regards
Chris
11 Feb 2015   #22
dsperber
Quote   Quote: Originally Posted by jaspergap View Post
No I don't even have 4 tabs for my speakers... I only have 2: speaker configuration and default format. ThaThat's the problem.. On my pc downstairs I do have the same window like in your screenshot, but my laptop does not
I suspect your laptop is using Realtek audio driver provided by ACER, similar to my own Realtek audio driver provided by Lenovo for my W530 laptop.
On my W530 laptop, I have a Realtek audio chip (ALC3202), and I also show Realtek HD Audio Manager in Control Panel. But like you with your Aspire 5750g the Realtek HD Audio Manager only shows the same TWO TABS, and does not provide the additional tab for "sound effects" which is where the Realtek-provided EQ interface would be presented.
HOWEVER...
The reason for this on my Lenovo W530 is very simple: Lenovo's Realtek audio driver includes Dolby Home Theater v4, which is where the actual audio capabilities reside. It is the Dolby software where the EQ (from Dolby) is provided. There is a Dolby icon present in the System Tray which can be opened to show a minimal interface, and if you click on the "gear" (settings) the full GUI appears which provides a bunch of EQ presets as well as the ability for you to customize and create your own EQ setups.
I believe I found some Interweb references to the Aspire 5750g also mentioning a Dolby shortcut object on the desktop. This suggests to me that your ACER-provided Realtek audio driver probably includes Dolby Home Theater as well. And that is where you should be looking for your EQ setup on your laptop.
I have a hunch that even if you try to use a retail Realtek-provided audio driver installer package, that even though it might install and produce sound on your laptop that there's something unique about the vendor-specific hardware/BIOS in the laptop that says the Realtek driver should NOT provide EQ capability, because the hardware vendor intended Dolby software to be used. And that Dolby software is only going to be present using the vendor-provided audio driver, not the Realtek-provided audio driver.
I think Dell's machines have a similar setup, with IDT HD Audio (instead of Realtek HD Audio). Again, you need to get the audio driver from Dell, because that package includes everything designed to run on a Dell laptop.
Same with my Lenovo W530 with its Realtek audio plus Dolby Home Theater. And probably the same with your Aspire 5750g. It's just apparent that the Realtek driver understands it should NOT be presenting EQ capability, and thus doesn't present that tab from HD Audio Manager.
Realtek HD equaliser backup/restore
Hi everyone, i really need some help concerning my Realtek HD equaliser.. My computer crashed and i just installed a fresh version of Win7 ultimate x64 on my pc and i would like to know if its possible to get back my custom equaliser for Realtek HD sound manager!!! like is it saved somewhere in...
Backup and Restore
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
ASUS/Realtek, Latest Realtek versus default W7 Audio driver
I installed the Realtek HD audio driver from the ASUS download site (P8Z68-V Pro MB) and all was well until I installed an MSI 560TI video card and let it install the Nvidia HD Audio drivers. The problem I have been chasing ever since was the Realtek HD Audio Manager popping up after the system...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
