Windows 7: Using a Graphic Equaliser With Realtek Audio?
10 Feb 2014   #1
Chris Nicola
Windows 7 Ultimate 32 bit SP1
I am playing an analog device through my sound card with 2 channel stereo and am wondering if Realtek have a built in graphic equalizer somewhere as I can't find one. If Realtek don't have an equalizer is there a third party software that can do the job? Your advice would be appreciated.
Kind Regards
Chris
PS The Realtek audio driver shows up as 6.0.1.7083.
11 Feb 2014   #2
Roderunner
Win7 H.Prem. 32bit+SP1
Hi Chris Nicola, I wouldn't bother setting Realtek, just set the app you use to play music. I use Winamp.
11 Feb 2014   #3
fireberd
Realtek (all that I've seen) contains EQ for various settings.
Go to Control Panel/Hardware and Sound. Access the RealTek HD Audio Manager. Using the RealTek it will be applicable to any audio, not just within a media player.
See screen shot:
11 Feb 2014   #4
dsperber
Quote   Quote: Originally Posted by Chris Nicola View Post
This is the latest Realtek driver, but out of curiosity what is the chip on your motherboard?
You should have the "Realtek HD Audio Manager" icon in your system tray. Right-click on it and select "sound manager" to open it. Then click on the "i" (info) button to display details of your Realtek chip.
To get to the Realtek EQ (assuming your chip supports it), select the "Sound Effects" tab from the menu at the top of the opening presentation when you get into "Realtek HD Audio Manager". Then down about 2/3 of the way on the left side of the window there is a "change to graphic EQ" button. Click on it, and you'll now have a 10-band EQ that you can adjust. The adjustments will have a real-time effect on sound, so if you're playing something while adjusting that's a good way to come up with the slider settings you like... at least for that particular sound/music that you're playing.
When you're satisifed with that particular EQ setup, push the "save" (floppy disk icon) button to the upper-right of the EQ itself. Pick a name to save the EQ as, and it's now in effect indefinitely until you change it or select some other preset or one of your own other custom-saved EQ settings.
Note that Realtek's GUI is now potentially different (i.e. a different skin) depending on manufacturer and motherboard. My screenshots above are from an ASUS board, but whether your "skin" is the same or not the HD Audio Manager and "sound effects" tab is still the place to set up your collection of custom-saved EQ's, both to save them and then to select them.
11 Feb 2014   #5
Chris Nicola
Thank you all for your replies. I finally found it in the control panel under Hardware and sound / Realtek audio manager. I also found it in the system tray. It was so simple and I missed it for so long. The graphic equalizer and the presets are all there as seen in the screenshot from Fireberd. I was previously looking under the sound icon in control panel instead of Realtek HD audio manager. Thank you all for your help.
Kind Regards
Chris
21 Oct 2014   #6
jargraj
Win 7 Home Premium 64 bit
No Sound Effects Tab or Graphic EQ
I know exactly what I want because it looked a bit like in dsperber's post on my old Acer.
I have just reinstalled the most recent Realtek driver, codec and software package direct from their site, and I can't get a graphic EQ up using HD audio manager. I can only see Default Format and Speaker Configuration tabs.
win 7 64 bit. aspire 5750g.
I appreciate this thread has been inactive a long time but my problem is almost directly related.
P.S. I tried clicking most of the exe.s in the realtek install folder and nothing happened. rthdcpl.exe vncutil64 etc.
21 Oct 2014   #7
Chris Nicola
Do you mean you can see Realtec HD audio manager in Control panel but when you launch it you cannot find the equalizer? Check the settings in this screenshot.
https://www.dropbox.com/s/z0n8o4ohaq...liser.JPG?dl=0
Kind Regards
Chris
24 Oct 2014   #8
jargraj
Aye I can see the audio manager, but in it I can't see a sound effects tab or a digital output tab.
The speakers tab has "speaker configuration" and "default format" tabs and the microphone tab has "microphone effects" and "default format" tabs, and that's all i can see. no EQ.
24 Oct 2014   #9
jargraj
Also, when I plug something into the headphone jack a new turquoise window pops up, but this too has no eq options, only Audio I/O and Power Management. The Audio I/O tab has microphone and speaker options and a demo sound window. that is all.
24 Oct 2014   #10
Chris Nicola
Please can you send a screenshot of what you can actually see.
Kind Regards
Chris
Realtek HD equaliser backup/restore
Hi everyone, i really need some help concerning my Realtek HD equaliser.. My computer crashed and i just installed a fresh version of Win7 ultimate x64 on my pc and i would like to know if its possible to get back my custom equaliser for Realtek HD sound manager!!! like is it saved somewhere in...
Backup and Restore
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
ASUS/Realtek, Latest Realtek versus default W7 Audio driver
I installed the Realtek HD audio driver from the ASUS download site (P8Z68-V Pro MB) and all was well until I installed an MSI 560TI video card and let it install the Nvidia HD Audio drivers. The problem I have been chasing ever since was the Realtek HD Audio Manager popping up after the system...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
