Windows 7: How To Stream Different Audio To Different Sound Outputs?
10 Feb 2014   #1
leo45
Windows 7 Ultimate 64bit
First time poster, so I'm not sure it's the right sub, but anyways:
My graphics card has two DVI outputs and I'm only using one for my single monitor. I also have a wall-mounted LCD TV with HDMI inputs in another room and I'd like to be able to stream movies and stuff from my computer to this TV.
So, is there a way to somehow channel only desired sound streams to this TV (i.e. if I'm playing a game on my main display and also a movie is being played on my extended display, how can I tell the computer to play game audio in my earphones and play movie audio through TV speakers)?
Thanks.
11 Feb 2014   #2
fireberd
If you do not have an HDMI output on the video card, you would have to send the audio separately to the TV. DVI does not contain audio. Even if you have a DVI to HDMI converter it still would not contain audio.
However, most TV's that have an HDMI input will not be able to be setup for audio from another source at the same time.
Best option is to change the Video card to one that has built in audio and an HDMI connection. That will solve the problem of getting HDMI video/audio to the remote TV. Keep in mind when you use the HDMI connection, you will not have the regular PC audio (Speakers). Windows only allows one default audio playback device, e.g. either "Speakers" or HDMI.
11 Feb 2014   #3
Barman58
Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
The routing of sound is as much dependent of the software that you use as the hardware. You obviously require suitable hardware, but the choice of software is also an important consideration.
I run a DVI link via a HDMI lead to my main monitor, (32" HDTV), and a full HDMI Lead to my secondary monitor (39" HDTV). I also made the assumption that DVI did not carry sound, but with just the DVI connection I get Stereo output from my main Monitor's built in speakers, so It may actually be that the DVI does not provide 5.1 sound, which is carried via HDMI.
I can run my Main monitor output as the default sound device, whilst at the same time I can set VLC to send its output direct to the Secondary monitor via HDMI in 5.1.
Certain apps allow this type of sound splitting/Routing whilst others only have the option to send sound to the default sound device
I also have a third sound output, The built in Realtek HD on the motherboard, I have a set of 2.1 speakers attached but find I use this more for headphone use, I am able to have VLC output to the Secondary Monitor for others to watch streamed content whilst I can listen to other output via headphones
How can I use 2 audio outputs at once?
I use an HDMI cable to connect my PC to my TV to watch TV shows. I would like to separate and choose what program audio comes from which device. I would like, say for example, Garry's Mod to come from my PC speakers while Windows Media Player comes though my TV speakers. When I go to start>search>...
Dual monitors, different audio outputs?
I have my monitor (vga) and my tv (hdmi) hooked up to my desktop computer. When I listen to music I have it open on my monitor and the sound comes through the bookshelf speakers I have connected via the audio jack. However when I want to watch a video, I watch on the TV and I want the sound to be...
Cannot get two audio outputs from one soundcard
Recently I purchased a new headset. It connects to the computer through two 3,5mm jacks, a mic out and a sound in. (Never buying anything without USB again...) My regular speakers are also connected through a 3,5mm jack. I've attempted to keep my speakers plugged in the rear and my two headset...
2 audio outputs? Help with sound card
Hey, I know this is a topic that must have came up so many times, but after trying several methods on Google, I've had no luck. So yeh, I'm wanting to have 2 separate audio outputs. So I first had an output coming from the motherboard. I then added a sound card as I beleived this would allow me...
How do I configure WMC to have two audio outputs?
My computer is in one room and TV is in another. I use the stereo plug to power the small satellite speakers at the computer and the HDMI cable from the mother board to drive the TV in the adjoining room. I would like to have sound in both rooms, but WMC seems to restrict one to either/or......
Media Center
One PC, Two monitors. Two Audio outputs possible?
I found this gem of a forum when I finally upgraded my computer recently, used it plenty of times, however got a small issue that I thought this forum could out with. My setup Dell XPS 8300 ATI HD 5770 Gfx card Windows 7 Home premium 64bit Standard widescreen monitor connected to the...
