Need Help Please Audigy
Hey Guys im new to this forum and hopefully can get some help as I have spent the last few days trying to figuer this out and no luck.
I have a SB Audigy card and i have resently installed windows 7 and i have installed the drivers for the card from creative and windows update (both seem to be the same) this is where it gets wierd.... If i open the sound properties and configuer the speakers to 5.1 and test them they all work fine ( i have a 5.1 home theater system plugged in using multi channel in) But when I play music via itunes/media player or play movies via vlc/media player there is no Bass at all yet when i test the sub bass comes out.... ?
i have tryed unistalling the drivers and tryed installing the support pack from daniel k but they wont install at all.
In winXP it had the same problem but you could open the consol and turn the bass on and set the frequency but in win7 i dont even get that option i dont even get the proper consol (the one that looks like a silver amp)
anyway thats my crazed situation,any help would be really appreciated to my no bass problem.
Thx guys
