Windows 7: Rosewill N300 PCI Wireless Card Broke my Realtek HD Audio
19 Feb 2014   #1
Porkchops007
To start off, I'll tell how it all happened. First, almost 3 months ago I bought a PCI Wireless card from newegg, it came in a week later and it was defective. I returned it for a new one and got it another two weeks later (Very slow shipping). It was working, but when I installed what was on the disk it came with, my HD Audio Manager went wacky and said I was plugging in and out audio devices. I just clicked OK on all of them. So I got good speeds but I realized I hadn't any audio coming from my speakers. The realtek HD audio was set to default playback device and both ports on the audio jack were securely in. It simply wouldn't work. A restart didn't fix it either. So I uninstalled and reinstalled the drivers for the PCI Wireless card a couple of times, restarting time after time just going through troubleshooting processes in hope that one would fix it. So during the process, after the first time of uninstalling I found the card defective again only giving 0.8Mb/s download speed just as the first defective card. Over the whole convoluted process I hadn't fixed my speakers, my mouse drivers broke so I had to put it into a different port, and I have another defective PCI wireless card. So my question is, how would I fix my speakers? The speakers are in my monitor and what it's usually named is Realtek HD Audio or something but now it's named High Definition Audio Device. Are there any fixes I can try? Or is more information needed? Thanks!
20 Feb 2014   #2
fireberd
High Definition Audio Device indicates that the generic basic function Windows installed audio drivers are installed instead of your RealTek.
Reinstall the RealTek, either from the installation disc that came with the motherboard or from the ASUS site for your specific model motherboard.
As far as the Rosewill PCI card, first you should be using a PCIe card, not a PCI as the PCI bus on most newer motherboards is a "bridge" to the PCIe bus and many PCI cards do not function correctly with the bridged PCI slot. Second, I would get something other than Rosewill, which tends to be a "cheaper" brand.
Another issue I see is two Antivirus programs. Having two programs, like you show (Microsoft Security Essentials and Avast) will conflict and can cause many problems. I, and all my clients, only use the Microsoft Security Essentials and Malwarebytes (for malware/spyware).
20 Feb 2014   #3
Porkchops007
Asus doesn't have the audio drivers on their site (None at all). I looked up my mobo and then audio drivers and found some realtek audio driver installer (Looked the same as the comes from Realtek, so it wouldn't matter which one I downloaded) and installed it. One restart later, it detected that I unplugged something, though I didn't. I unplugged it and plugged it back in and it still won't give any audio to my speakers (In my HP w1858 monitor). It still won't work, it just gives some static as it did before with this motherboard (One person told me it could be because of some EMF stuff or something).
20 Feb 2014   #4
fireberd
How are you connecting to the Monitor? VIA a DVI connection for the video and an audio cable from the PC's speaker (green) jack to the monitor? Or is it an HDMI connection?
08 Mar 2014   #5
Porkchops007
VGA
I'm using a VGA cable and an audio jack. For some reason though, I can hear fuzz coming from my speakers. Like it's picking up frequencies. It's not intentionally from the computer though, it's not showing up as sound in my volume. This was here before it gave no sound though. The oddest thing out of all about this is that when I run certain programs, move my mouse, open up a picture, simple functions like that, the fuzz will change to a different pitch. This may be my motherboard?
08 Mar 2014   #6
fireberd
Have you tried a headset? May be there is a problem with the speakers and/or cable rather than the sound device?
08 Mar 2014   #7
Porkchops007
I'm using my Logitech G930 headset right now, but it doesn't use an audio jack. It uses a USB 2.0 because it's wireless. When I plug a speaker, however, it gives off that fuzz still. I believe it is my motherboard now. I don't want to return my motherboard though, it'd be too much work to take out my CPU, heatsink, wires, everything. Even the speaker I plugged in won't give any sound. I'm afraid it physically damaged my motherboard. The only way I'll know I guess is to boot of of something else (E.g. ubuntu) and see if I can get sound.
09 Mar 2014   #8
fireberd
Sending a motherboard back for repair is a hassle, but if that's what it takes to get the sound working again, its the only option if you want sound. I just sent my Gigabyte motherboard (in January) back for warranty repair. Its a hassle, but now I have a fully functional motherboard. The system with the Gigabyte motherboard is my recording studio system, fortunately I have a backup system that I used while it was down for service.
Issue with Netgear N300 wireless and dropping connection
Hi there, Recently bought an N300 wireless adapter for my PC. I have a normal router which I usually connect to the internet using an ethernet. But sometimes I go wireless. Initially it all worked wonderfully, without the ethernet my PC was able to pick up the wifi and I could browse,...
Network & Sharing
no sound ,Win7-ultimate x86,realtek high definition audio card
hi i had windows Xp Sp2 for several years and yesterday i have upgraded to Win7. everything went fine except for the sound. i have K9A2 cf-f MSI main-board with on board realtek high definition audio card(i saw the name on device manager it was below of AMD high definition audio device).after...
Rosewill Wireless N Adapter Yellow Triangle Trouble
Hey everyone, i'm having a real problem with my Wireless N adapter working.. I have had this working before, but took it out of my PC months ago. Now i would like to put it back in and use it some more, but I have that dreaded yellow exclamation point triangle in my device manager.. when i use...
Network & Sharing
Netgear N300 Wireless Adapter Default Gateway is not Available
So I had just finished building and setting up my new rig yesterday and today I got a Netgear adapter. I installed everything and it went fine until it started going in and out giving me the "Default Gateway" error. I searched for what is now 4 hours and tried every solution possible, but I cannot...
Network & Sharing
Realtek ethernet and wireless CARD problem
I have some problems with these two Realtek card, before installing windows 7 all was ok (using XP) : Problems: 1) Some downloads from particolar site do not start and remain in waiting, for example I can not donwload from HTML.it web site. I think that it depends by download protocol used by...
Drivers
Rosewill RC-200 raid card issues with Windows 7
Hi, First post.. I just installed Windows 7 and for the most part all went ok. The only issue I seem to be having concerns my Rosewill RC-200 IDE raid card. Card works fine as an IDE card. However, I cannot get the raid functions to work. The card uses a “Silicon Image SiI 0680 ATA-133...
Hardware & Devices
