Windows 7: No audio input device problems
06 Mar 2014   #1
stevedore
8X64
I recently purchased a new pc laptop, but I had a problem, I tried to set up my new headset but I got the "no audio input device found" I spent about two hours searching what the problem could be, I needed to update my driver, after I updated my driver to realtex I got the "you just plugged in a device to your audio jack" and It still isn't working. it works only for the speaker part of my headset, not the audio part, any Ideas?
06 Mar 2014   #2
fireberd
Please fill in the "My System Specs" so we know what hardware you have. It helps us to try and help you.
Also what headset/mic are you using? If its one designed for an iPhone/iPod, it is a "trrs" type plug and that is incompatible with PC's and needs an adapter.
06 Mar 2014   #3
stevedore
8X64
Its taking a really long time for me to put each spec in the "my specs" category so ill put my specs here (might be a lot)
specs:
System Information
Time of this report: 3/6/2014, 19:57:19
Machine name: STEVENSCOMPUTER
Operating System: Windows 8 64-bit (6.2, Build 9200) (9200.win8_gdr.130531-1504)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X551CAP
BIOS: X551CAP.203
Processor: Intel(R) Celeron(R) CPU 1007U @ 1.50GHz (2 CPUs), ~1.5GHz
Memory: 4096MB RAM
Available OS Memory: 3982MB RAM
Page File: 2812MB used, 3153MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0270&SUBSYS_1043145D&REV_1001
I took off most of the stuff I don't think was needed
06 Mar 2014   #4
stevedore
8X64
and the headset is SADES SA-708 gaming headset
07 Mar 2014   #5
fireberd
That headset, from what I find, has a microphone volume control. If the speaker part of the headset is working, but the mic is not that is one place to start.
Looking at that PC on the ASUS site, there are two RealTek drivers and according to the site, if you have Windows 7 you should use the older listed driver.
Another issue, since you installed the RealTek driver, I assume it originally had the generic Windows installed basic function HD Audio Codec drivers. If these were not uninstalled they can cause conflicts and devices to not work.
Several possibilities.
Please post Screen shot of the Device Manager, Sound Video and Game Controller section.
07 Mar 2014   #6
stevedore
8X64
yet again I wasn't sure how to do screenshots and move it to here, so I attached the file here
08 Mar 2014   #7
fireberd
Whatever the Bluetooth device is, it may be causing the problem? Disable that (temporarily) and see if it makes a difference.
You can disable it in the Device Manager, RIGHT click on the entry and then LEFT click Disable.
08 Mar 2014   #8
stevedore
8X64
I still got nothing, and also, I noticed when it says "you just plugged a device into the audio jack" it only comes up when I have the headset piece plugged in before I turn on the computer
08 Mar 2014   #9
fireberd
Looking back at the original post. You stated a new PC and you had to update the driver to Realtek. That suggests an initial setup problem, and in that case the PC vendor support should have been contacted. Whether it is just a "bad load" and the PC needs reinstalled or if there is a hardware problem.
On a new PC, unless the initial manufacturer install was bad, you should not have to install drivers to get something to work.
If you want, on your own, if ASUS has a procedure to reinstall the PC back to the original factory setup that may be a good step. I would suspect that is the first thing that ASUS will tell you to do (typical vendor support "fix").
10 Mar 2014   #10
stevedore
8X64
alright ill try that
Microphone No Audio Input Device Found
Hi. I want to try using my microphone when I am playing some games and doing other things but I just noticed that the microphone device cannot be detected. Just so you know, I am using a Gaming headset that has a built-in microphone in it so I am pretty sure that the microphone's with it. Also, I'm...
No audio input device found
Hey everyone, I am trying to get my mic to work, but when I hit "set up microphone" it says "No audio input device found". I have a High Definition Audio Device installed and the sound works fine. However, under the "recording" tab in Sound it says there are no audio devices installed and the...
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
No Audio INPUT Device
I have an Asus P6T motherboard with Realtek ALC1200 on board audio and Windows 7 64 bit OS, DirectX 10, Audio Driver version 6.0.1.5859. The sound works normally for all audio functions. I installed Nero and went to use the Wave Editor application to record a song from the web and got the...
How do i fix my multimedia audio controller & pci input device driver?
My mobo is foxconn G31MV-K, Socket 775 Processor : Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz @2.00Ghz RAM : 1.00 GB OS : Windows 7 Ultimate 32-bit Audio: 5.1 HD audio by Realtek® ALC662-GR The main problem is the multimedia audio controller & pci input device in the device manager always...
Dell Dimension Upgrade - No Audio Driver/PCI Input Device?
I just upgraded an older Dell Dimension 4600 desktop from Windows XP to W7 (32 bit). Since completing the upgrade, there's a message in the lower right hand corner stating "No Audio Output Device". When I click on Devices, both the Multimedia Output Controller has a "!" as well as the "PCI Input...
Drivers
