No Audio output Devices Sony Vaio Wgn-fs730
  1. Posts : 4
    Windows 7 Enterprise
    Just converted a friend's 2005 vintage Sony Vaio FS730 laptop XP system to Windows 7. Sony has no drivers for this machine beyond XP. Their available Vista drivers seem to be for different hardware.
    The machine runs OK, but there are no sound output devices using the windows default installed "HD audio codecs." Using this driver there are no output sound devices found (disabled and hidden included) but the driver appears to function. Plugging headphones/speakers into the jack gives no sound and nothing from the built in speakers.
    I've downloaded the Realtek drivers version 2.73, uninstalled the existing drivers, and installed twice, but get a Blue Screen of Death (BSOD) after installing.
    The hardware code for the device from msinfo32 components is
    Realtek
    PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0260&SUBSYS_104D0000&REV_1003\4&10F4C67C&0&0001
    Any clues or suggestions on getting audio functioning on this machine would be greatly appreciated.
  2. Posts : 18,415
    windows 7 home 64bit
    Hi Welcome to Seven Forums ... Try the Driver in the Link below ..
    Sony eSupport - VGN-FS920 - Drivers & Software
  3. Posts : 4
    Thank you for responding. Tried it twice in administrator mode, once running Vista Compatibility mode, no joy.
    Received message "This update not intended for use on your computer model"
    No bypass allowed, install fails
  4. Posts : 18,415
    I think your out of luck my friend .. The hardware is just to old for Windows 7 ..
  5. Posts : 4
    I fully agreed with your comment and ALMOST reverted to XP when I decided to search on the device code
    and on this site's page Download Windows Drivers - hdaudio\func_01&ven_10ec&dev_0260&subsys_104d0000
    I looked for the most recent driver, I went with a Dell driver ftp://ftp.dell.com/audio/R306840.exe and surprise it worked. Sound was a bit low but after opening some of the controls and setting the volume to 100%, then setting volume equalization on it works great.
    I knew doing something like this was possible after getting sound to work on my older Dell machine using another machine brand's driver.
  6. Posts : 18,415
    Well done .. Yes i have used other Manufactures Drivers in the past with good success .. Its a matter of trial and error though ... I really did think the Hardware was just to old .. But very pleased to be proved wrong :) And thanks for Posting back your Solution ...
  7. Posts : 4
    I'm ready for St Patrick's Day. Enjoy.
