Windows 7: No Audio output Devices Sony Vaio Wgn-fs730
12 Mar 2014   #1
kokopelle
Windows 7 Enterprise
Just converted a friend's 2005 vintage Sony Vaio FS730 laptop XP system to Windows 7. Sony has no drivers for this machine beyond XP. Their available Vista drivers seem to be for different hardware.
The machine runs OK, but there are no sound output devices using the windows default installed "HD audio codecs." Using this driver there are no output sound devices found (disabled and hidden included) but the driver appears to function. Plugging headphones/speakers into the jack gives no sound and nothing from the built in speakers.
I've downloaded the Realtek drivers version 2.73, uninstalled the existing drivers, and installed twice, but get a Blue Screen of Death (BSOD) after installing.
The hardware code for the device from msinfo32 components is
Realtek
PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0260&SUBSYS_104D0000&REV_1003\4&10F4C67C&0&0001
Any clues or suggestions on getting audio functioning on this machine would be greatly appreciated.
12 Mar 2014   #2
maxie
windows 7 home 64bit
Hi Welcome to Seven Forums ... Try the Driver in the Link below ..
Sony eSupport - VGN-FS920 - Drivers & Software
12 Mar 2014   #3
kokopelle
Thank you for responding. Tried it twice in administrator mode, once running Vista Compatibility mode, no joy.
Received message "This update not intended for use on your computer model"
No bypass allowed, install fails
12 Mar 2014   #4
maxie
I think your out of luck my friend .. The hardware is just to old for Windows 7 ..
12 Mar 2014   #5
kokopelle
I fully agreed with your comment and ALMOST reverted to XP when I decided to search on the device code
and on this site's page Download Windows Drivers - hdaudio\func_01&ven_10ec&dev_0260&subsys_104d0000
I looked for the most recent driver, I went with a Dell driver ftp://ftp.dell.com/audio/R306840.exe and surprise it worked. Sound was a bit low but after opening some of the controls and setting the volume to 100%, then setting volume equalization on it works great.
I knew doing something like this was possible after getting sound to work on my older Dell machine using another machine brand's driver.
12 Mar 2014   #6
maxie
Well done .. Yes i have used other Manufactures Drivers in the past with good success .. Its a matter of trial and error though ... I really did think the Hardware was just to old .. But very pleased to be proved wrong And thanks for Posting back your Solution ...
12 Mar 2014   #7
kokopelle
I'm ready for St Patrick's Day. Enjoy.
No Audio Output Devices is Installed- Sony Vaio
I have a bluetooth headset that already paired but it is unable to use because there is no audio services to work with. When I run the troubleshooting for my sound, it couldn't identify the problem. In my device manager, the bluetooth audio is gone (it used to be there) and i also have many unknow...
No VGA or HDMI output on my Sony Vaio Lap after upgrade to windows 7
There is no VGA or HDMI output on my Sony AR VGN-AR51M after upgrade to windows 7 from vista, yet my Driver Support program says my Standard VGA Graphics display adapter is working ok. I have tried installing various updates and new display drivers but will not accept them and says...
Hardware & Devices
Sony VAIO laptop "No Audio Output Device Installed"
Warning, I am NOT a computer person at all, but have spoken to some and tried several repairs. I have a Sony VAIO VPCEA24FM laptop, running windows 7 64-bit and the sound has randomly stopped working (made no changes to anything that I know of). There is a red circle with an x in it on the volume...
Audio configuration no audio output devices?
my computer's sound has stopped. I have searched through lots of websites looking for help. I first noticed this problem when I tried to open iTunes and it came up with the message 'iTunes has detected a problem with your audio configuration. Audio/video playback may not operate properly'. I also...
How to switch between audio output devices?
Recently got a USB headset, and I have speakers plugged in as well. How do I switch between the two when I want audio to only come from speakers and vice versa? I took this screenshot if it helps: http://puu.sh/FWMO
No HDMI output when lid closed - Sony Vaio Z2 with Intel HD 3000
Hello folks, I have setup extended monitors, and when I close laptop lid video on TV stop playing and shows me desktop from laptop. Tried "do nothing" when lid closed but that didn't do the trick. My old Vaio VGN-Z (Nvidia Geforce 9300GS) had no issues when closing laptop lid. Any idea how...
Graphic Cards
