Windows 7: Microphone Quality Problems
12 Mar 2014   #1
Orange Manatee
Windows 7 Professional
I do gaming commentaries with my friend and I use Nvidia Shadowplay to record. Recently I got a Samson Meteor, reading really good reviews about it. It was great the first few weeks, but lately it has had worse and worse quality. I have tried using Audacity and that records my voice perfectly but of course it doesn't record his. When I record my voice in Shadowplay the quality is really bad and I can hear my keyboard and mouse clicks and everything.
Is there any way to solve this?
13 Mar 2014   #2
fireberd
Since it records OK in Audacity, it says the microphone and the PC's sound card are OK. The problem is in the specific application, Shadowplay and/or all the other applications that are running at the same time.
Check to see if there are any settings or if others have had audio quality problems with Shadowplay.
I'm not a gamer and know nothing about that application. Maybe posting in the gaming section will get some help with that.
Headset microphone problems
Hi guys, been having a real problem lately. I bought a nice new corsair vengeance 1300 headset to go with my 600t case. However when i plug them in to the front jack the mic doesn't work. I know the mic works because i have tested in the back panel. Also when i plug them into the front panel i get...
Microphone problems.
So yesterday while i was playing on my PS3 while talking on skype, i decide to go to the bathroom with my headset on to brush my teeth, so lalala in i go and when i lowered my head my mic fell out of my headset and into a (semi deep) pool of water for about 2 seconds, ever since then to even hear a...
NVIDIA GeForce 310M - problems with WEI and video quality?
I bought a new laptop - ACER 5745G. After the initial Windows 7 64bit installation my scores were 6.6, 5.9, 5.9, 6.0 and only the Graphics for Areo a 4.9. Since I mostly want to use this laptop for watching HD videos, I figured those are scores aren't low and was satisfied. However, after...
Graphic Cards
Microphone strength problems
Hello, i used to have an audigy 2 zs platinum pro, and with it there was a rack unit with a preamp for mic.. now.. it looks like it died on me last night, and so for the time being im stuck with the onboard audio.. the problem i have is that the onboard audio (Via 2020, software x-fi...
windows 7 microphone problems
hello everyone... the problem i am having is i am trying to record a small podcast using audacity, and it picks up my headset microphone no problem, the problems though is that audacity is also recording all system sounds too... i want to disable this so it only records my microphone i have...
Microphone Problems PLEASE HELP!
I have recently wiped my laptop and reinstalled with windows 7 and have been having problems with microphones ever since. Originally I was trying to fix the built in microphone, but now I have bought a brand new microphone. The problem is the microphone is not picking up sound correctly. It...
