Friend Can't Hear Me On Skype
  1. Posts : 24
    Windows 7 Enterprise x64
    I just took a Skype call and the person I was trying to talk to couldn't here me. I went through Skype's troubleshooter, calling the Skype Test Call number which records your voice and plays it back to you and I couldn't hear myself, so I went on to the next stage which involves troubleshooting Windows 7.
    I downloaded MicrosoftFixit.AudioRecording.LB.533177034617286.6.1.Run.exe, but when I try to run it, I get this error:
    "We’re sorry, but the program encountered an error trying to contact the server. Please try again later.
    To download a utility to troubleshoot this problem click here
    [code 80072EE7]"
    I downloaded the software it linked to which was called DIAG_MATS_NETWORK_global.DiagCab and ran it, but it said it couldn't fix the problems it detected. Here are the details:
    Microsoft Automated Troubleshooting Services Diagnostic Publisher details
    Issues found
    Check for connections to URLs used in SDP Service
    Detected
    Unable to reach to one or more URLs needed for a diagnostic package to run successfully Completed
    Issues found Detection details
     Check for connections to URLs used in SDP Service Detected
    There is a problem to connect to one or more URLs needed for a SDP diagnostic package to run: A connection to one or these URLs returned an unexpected HTTP Status Code. Please review the Information Collected below for a list of URLs that are needed for a diagnostic package to successfully execute from the Internet and that returned HTTP status codes different than the expected. If you use Proxy servers on your organization, you may need to have the Proxy servers configured to open these URLs. You may also try connecting from a different machine. A workaround to avoid problems to connect to the Internet when running diagnostic packages is to contact Microsoft and ask for a Support Engineer to generate an portable executable (.exe) and send it to you. A portable executable file does not require Interent access.
    Additional Information
    Information Collected: URL : https://support.microsoft.com
    Returned HTTP Status Code : [NameResolutionFailure] The remote name could not be resolved: 'support.microsoft.com'
    Expected HTTP Status Code : 200
    Information Collected: URL : https://dcupload.microsoft.com/tools/win7files/VersionCheck.txt
    Returned HTTP Status Code : [NameResolutionFailure] The remote name could not be resolved: 'dcupload.microsoft.com'
    More Information
    Symptom: You may not be able to download a diagnostic package directly from the Internet as one or more URLs responses/ status codes were unexpected. This is usually caused by a Proxy Server, configuration or problems with the service
    Public Content: http://support.microsoft.com/kb/2598970#q13
    Detection details
    Operating System
    Machine Name: JOE-PC
    OS Name: Microsoft Windows 7 Ultimate Service Pack 1 64-bit
    Build: 6.1.7601
    Time Zone/Offset: (UTC) Dublin, Edinburgh, Lisbon, London/0
    Last Reboot/Uptime: 3/24/2014 6:39:07 PM (12 Minutes 2 Seconds)
    AntiMalware: Microsoft Security Essentials
    User Account Control: Enabled / Admin Mode: Prompt for consent when programs make changes
    Username: Joe-PC\Joe
    Computer System
    Computer Model: System Product Name
    Processor(s): 1 dual core x64 processor Intel® Core™2 CPU 6700 @ 2.66GHz
    Machine Domain: WORKGROUP
    Role: Workstation
    RAM (physical): 8.0 GB
    Connection to URLs
    http://diagnostics.support.microsoft.com:  OK
    https://diagnostics.support.microsoft.com:  OK
    https://support.microsoft.com:  Failure
    https://dcodews.partners.extranet.microsoft.com:  OK
    https://dcodews.partners.extranet.microsoft.com/sdpservice:  OK
    https://diagnostics.support.microsoft.com/DiagExec:  OK
    https://dcupload.microsoft.com/tools:  Failure
    http://download.microsoft.com/download:  OK
    Internet Explorer Configuration
    Proxy Server: Disabled
    Automatic Detect Settings: Disabled
    Network Adapter Configuration
    Wireless Network Connection: Network Adapter Ralink RT61 Turbo Wireless LAN Card
    IP Addresses 192.168.0.2
    fe80::edfb:612f:5389:46e6
    Default Gateway 192.168.0.1
    DNS Servers 192.168.0.1
    Collection information
    Computer Name: JOE-PC
    Windows Version: 6.1
    Architecture: amd64
    Time: Monday, March 24, 2014 6:50:20 PM
    Publisher details
    Web pages have been loading very slowly for me lately and I'm getting a lot of 404 errors. Please can someone suggest how I can fix my problems?
    Thanks,
    Joe
  2. Posts : 1,261
    Windows 7 Professional X64
    [code 80072EE7]"
    Issues found
    Detected
    More Information
    Detection details
    Operating System
    Build: 6.1.7601
    Computer System
    Role: Workstation
    Connection to URLs
    Architecture: amd64
    Publisher details
    Thanks,
    Joe
    When I first installed Skype, I had that same problem.
    Found out I had to set Internal mic as default - then did record test and it allowed me to hear my voice.
  3. Posts : 24
    Thanks, it's working now.
  4. Posts : 1,261
    Glad it worked.
