Windows 7: Envy 24 5.1 sound works in vlc, the control panel but not in wmp wmc
13 Mar 2014   #1
sdowney717
How to get this to play using the minijacks surround sound in wmp and wmc?
VLC does play all the 5.1 channels, center with voices ok..
wmp and wmc only play stereo.
I went thru speaker setup for both wmp and wmc.
Envy 24 5.1 sound works in vlc, the control panel but not in wmp wmc-envy-241.png
26 Mar 2014   #2
sdowney717
I finally solved this problem with help from the thegreenbutton.tv web site.
WMC was trying to bitstream the sound out of this card, even though in sound settings panel it was set to speaker, NOT spdif.
The fix is to
Quote:
To test this theory, go to Tasks > Settings > TV > Audio. Check the box to enable Auto volume, then select Save. See if live TV results in audio output after enabling Auto volume.
And then it plays in WMC speaker test.
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
nothing works, cant right click, open my computer or control panel etc
Hi, I have a serious error on a laptop that my friend gave me, she is a college professor and gave me her laptop to fix it but i have absolutely no idea what to do. Laptop just seem to randomly stop working: -Right click menu wont open no matter where or on what i click (left click works but...
General Discussion
Editing the sound in Control panel
If you go to control panel/Sound & Sounds, I noticed that there are some programs there that I once had installed. Is there a way to remove/edit those old programs so that they no longer are listed? Tx
Windows 7 only works on safe mode -control panel says WD not activated
Hello My computer has started to play up after some updates were installed 2 days ago. I have tried system restore, but the tab for this is inexistent. Have been told to change some things in registery (Volume something, can't remember what's it's called now...) - I checked and sure enough, it's...
Windows Updates & Activation
Sound control panel configuration
I just got new 5.1 surround sound speakers and i have a couple of problems configuring them properly. 1. with higher frequency there's a static noise, which i believe has to do with treble, in the control panel the sound configuration doesnt offer any option to change this, any tool which i...
