Windows 7: Audio device not installed
13 Mar 2014   #1
Felis
Windows 7 Ultimate 32bit
Hi guys, I really appreciate for those who helping. My Sony Vaio has installed Windows 7 Ultimate for a long time ago. But recently, my audio has muted or whatever has happened. I tried to look up the sound system in Device Manager, none of the system listed is related to sound or audio. Troubleshooted also not helping. Not to forget, I have tried Recovery System as well to about a week before this and nothing happen. I have looked up into few forums to find the solution. Most of it is ask to try Realtek, but unfortunately, I downloaded and installed it until its asked to restart the computer and still nothing changed. Is there any others possible way to solve my problem before i format and change OS?
Regards,
Felis
13 Mar 2014   #2
RitualJman
Windows 7 Pro 64-bit
Have you tried downloading and reinstalling the drivers from Sony's website? Just to let you know that model of laptop that you have came with windows Vista Business if not here is the link to the drive. as well as if you wish you could reformat and return to windows Vista and that way you will know every thing is going to work the way Sony intended it to work. Also you can try downloading CCleaner and try cleaning the registery and removing junk files off your hard drive and then reinstall the drivers from Sony's website, might be something as simple as a dirty registry key.
VGN-TT16GN : TT Series : VAIO&reg Notebook & Computer : Sony Asia Pacific
The link below will let you download drivers, although when you select Windows 7 Ultimate 32-Bit then you need to select OS/Upgrade or Downgrade and scroll down the page and you will see the audio drive.
Support for VGN-TT16GN : TT Series : VAIO&reg Notebook & Computer : Sony Asia Pacific
https://www.piriform.com/ccleaner
Please let me know if this helped you and if this helps you please give Rep.
Thanks RitualJman
no audio device installed
i have compaq presario 5143il pc conf. intel core 2 duo, os win 7 ultimate sp 1 32 bit 3gb ram.500 hd problem error- no audio device found . troubleshoot error is one or more audio service isn't running(both the windows audio and the windows audio end point builder services must be running for...
No audio Output Device is installed?
Well today last night i updated my PC to windows 7 ultimate from windows vista, and my sound isnt there anymore, im not sure which sound driver i need. The pc is called Dell dimension 2400.
no audio device is installed
Just need to know how to fix this for my friend if anyone can help post on this :)
No Audio Output Device is installed.
I updated my sound card using a updating software and it changed into Realtek HD Audio. Now the problem there is no sound coming out and my sound mixer said that "No Audio Output Device is installed" but i have my speaker plugged in and when i troubleshoot it the troubleshooter said that :Audio...
No Audio Outut Device is installed
Hi everyone. I have just done a clean instal of win7 pro on my xp machine. everything is ok except that I have no sound from my onboard C-media 9880(mobo ms 7091). The sound icon in the taskbr is showing a red and wite cross and it says "No Audio Outut Device is installed" I have looked for...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
