Windows 7: Front panel headphone won't mute speakers and transfer audio
16 Mar 2014   #1
Windows 7 Ultimate 64Bit
I have a ASUS p5q pro turbo mother board and windows 7 64 ultimate. Did a format of the HDD for a fresh Windows install.
Before format when I plugged headphones into the front panel it used to cancel out the rear speaker jack and go to the headphones and when the headphones are unplugged it went back to the speakers.
It's not doing that anymore since the reinstall. I have installed the VIA audio from the original motherboard cd as the driver.
Anyone know how I can get the headphone to cancel the speakers again? Theres gotta be some hidden setting I found before that I'm not seeing this time.
Front panel headphone won't mute speakers and transfer audio-capture11111.jpg
Similar help and support threads for2: Front panel headphone won't mute speakers and transfer audio
Solved VIA HD Audio Deck - Front panel headphone device not producing sound Sound & Audio
front panel headphone socket is dead Sound & Audio
Solved Front headphone jack does not mute rear speakers Sound & Audio
Creative SB X-Fi will note mute speakers when headphone Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
