Windows 7: Controlling which Frequenzy Each Part Of Sound system Controls?
23 Mar 2014   #1
sisrace
Hi. My very cheapo Logitech Z523 Speakers is sure powerful and very good for its prize. But the bass has to be at max to do its job or atleast cover the speakers effort to output Bassnotes..
but i can only have it at 50% becouse otherwise my family gets grumpy to say the least :P
But when i lower the bass some Higher bass notes gets picked up and get outputted by the speakers and the bass! Wich ends up with a Good bass feel and the annoying sound of bad speakers trying to output good bass -.-.
So yeah it is very annoying to say the least and i wonder if there is any software that can control how the speakers act like Bass takes care of tones from 0Hz to 200/500Hz or whatever is the bass tones.. Im not really an extreme audiogeek but i love audio!
And say that the loudspeakers/speakers take care for 500Hz - 20Khz?
Or is this something the system has built in and cannot get changed and i was unfortunate enough that logitech messed it up?
23 Mar 2014   #2
fireberd
The actual power amplification and controlling of what frequencies go where is controlled by the electronics located in the bass speaker. You could install an Equalizer but you will still be constrained by the speaker system electronics.
I have a recording studio (using Sonar X3) and know what you want to do. You would need a much better system to have the full control over the frequency spectrum.
23 Mar 2014   #3
sisrace
it always ends up beeing expensive..
Ah well its good as it is im just trying to sqeeze every last bit out of it! :P
Not getting sound control or brightness controls, sony vaio
To start off, I had malware and adware in a few places, got that taken care of. My friend went through my services and disabled ones that he didn't see necessary. Now I can't control my sound level or brightness level, so my computer is on the darkest screen level. I work a lot on my computer,...
General Discussion
AOE 3 Parental Controls Issues on 64-bit System
Greetings, I am experiencing Parental Control issues on my Dell XPS L502X laptop featuring Windows 7 Home Premium 64-bit OS. After I purchased Age of Empires 3: Complete Collection on Steam and installed it I noticed that the game does not launch via Steam nor the executable file. An error box...
Gaming
Mysterious audio software is controlling my sound
Hi all, I have a dell XPS laptop with a plantronics .Audio 655 USB headset. Because I have Dell's "QuickSet" software installed whenever I increase or decrease the sound using either the keyboard or the buttons on the headset, the dell QuickSet software will display bars corresponding with the...
Is there any way to lock the sound controls?
I am a middle school teacher and in my lab, the kids keep going in and adjusting the sound. They either turn it all the way up, all the way off or mute it. I have been hiding the sound control on the taskbar, but they still adjust it. I would like to be able to lock the sound control so...
System Part and Boot Part Diff Drives. Want to Align SYS and BOOT
Alright here is my issue as best as I can explain it. I have two drives, one with a system partition one with my boot. The one with the boot is the drive I want to use as my primary. I want to format the drive with the system partition. How can I move the sys partition to the boot drive so that...
Installation & Setup
Sound card controls only headphones, not speakers!
Hi. I have a sound card problem after I installed Windows 7. Previously I had Windows XP and after I replaced OS some days after I noticed something weird - I can control headphones ONLY (volume, balance etc.) but my built in speakers are living completely independent life.:shock: If I`m playing...
