Windows 7: Microphone No Audio Input Device Found
08 Apr 2014   #11
ComputerGeek
Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
If you're saying that Device Properties shows Provider is Realtek, then you already have the driver installed. (The one driver is for the onboard audio speakers and microphone.
On the other hand, it wouldn't hurt to look in Program and Features look for Realtek and uninstall. Then download the driver from the support site and reinstall.
Otherwise, when you look at Control Panel->under Recording tab, do you see a mic listed? When you plug in the mic does it show detected? if not, it may the mic plug connection on the computer may have failed
09 Apr 2014   #12
zeromisery00
Microsoft Windows 8 Release Preview 32-bit 8400 Multiprocessor Free
I'll try reinstalling later if that's what causes the problem. On the Recording tab, it doesn't show the mic in the devices listed. I'm quite confused now because I've tried and tested that the mic works on the place where I bought it. Now it doesn't on my computer. Is it something external or does the pluggings are broken instead of the mic? Whenever I insert/remove something from it, it says that "you have plugged/unplugged a device from the audio jack". How do I fix that failed connection in the mic plug? Thanks.
No audio input device problems
I recently purchased a new pc laptop, but I had a problem, I tried to set up my new headset but I got the "no audio input device found" I spent about two hours searching what the problem could be, I needed to update my driver, after I updated my driver to realtex I got the "you just plugged in a...
No audio input device found
Hey everyone, I am trying to get my mic to work, but when I hit "set up microphone" it says "No audio input device found". I have a High Definition Audio Device installed and the sound works fine. However, under the "recording" tab in Sound it says there are no audio devices installed and the...
Windows will not recognise microphone input from external sound device
Hi, I'm running Windows 7 Home N SP1 x64. I'm using an M-Audio Fast-Track Pro device to record audio into a music sequencer (Cubase 5), through a Shure SM58 Microphone. The M-Audio box is connected to the computer via USB. I've been using this set-up for about a year now and it hadn't caused me...
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
No Audio INPUT Device
I have an Asus P6T motherboard with Realtek ALC1200 on board audio and Windows 7 64 bit OS, DirectX 10, Audio Driver version 6.0.1.5859. The sound works normally for all audio functions. I installed Nero and went to use the Wave Editor application to record a song from the web and got the...
How do i fix my multimedia audio controller & pci input device driver?
My mobo is foxconn G31MV-K, Socket 775 Processor : Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz @2.00Ghz RAM : 1.00 GB OS : Windows 7 Ultimate 32-bit Audio: 5.1 HD audio by Realtek® ALC662-GR The main problem is the multimedia audio controller & pci input device in the device manager always...
