Windows 7: Microphone No Audio Input Device Found
01 Apr 2014   #1
zeromisery00
Microsoft Windows 8 Release Preview 32-bit 8400 Multiprocessor Free
Hi. I want to try using my microphone when I am playing some games and doing other things but I just noticed that the microphone device cannot be detected. Just so you know, I am using a Gaming headset that has a built-in microphone in it so I am pretty sure that the microphone's with it. Also, I'm quite sure that I have a sound driver installed since I am always using it whenever I do something on my computer. Just that I noticed recently that the mic is not working. It's on good condition since I just have bought it about 3 months ago and tried and tested the microphone on the place where I bought it. Please do tell me what to do because I can't pin point the problem exactly on my computer. I've followed the instructions on how to put my pc specs on the forums and everyone's help will be greatly appreciated.
I hope to hear from you guys soon, thanks a lot in advance. Thank you!
02 Apr 2014   #2
HarriePateman
Windows 7 Ultimate 64-bit
Do you have It plugged in correctly?
What program manages the sound on you PC, I.E mine is Realtek
02 Apr 2014   #3
zeromisery00
Quote   Quote: Originally Posted by Harribo2014 View Post
Yes I do. If I'm not mistaken, my CPU has 3 plugins by default and I'm quite sure that I've inserted it correctly. If not, the audio wouldn't be available to hear. Also, Realtek is what I use.
03 Apr 2014   #4
zeromisery00
bump
04 Apr 2014   #5
zeromisery00
bump. please help me
04 Apr 2014   #6
zeromisery00
bump
05 Apr 2014   #7
HarriePateman
Please read forum rules. Bumping is not aloud.
Have you gone in into "Realtek", and set it up as a microphone?
05 Apr 2014   #8
zeromisery00
Sorry. But I am really desperate to get this fixed.
Going back, where do I locate that?
07 Apr 2014   #9
ComputerGeek
Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
Go into device manager. Locate the audio device.
> Right click->Properties->Driver. If the Provider is Microsoft, you're using the Windows generic driver.
If that's the case, go to your computer or m/b support site. Download the device specific driver for your machine and version of Windows
08 Apr 2014   #10
zeromisery00
Quote   Quote: Originally Posted by ComputerGeek View Post
I have realtek. Does that mean I have to download that for my microphone to work? Okay.
No audio input device problems
I recently purchased a new pc laptop, but I had a problem, I tried to set up my new headset but I got the "no audio input device found" I spent about two hours searching what the problem could be, I needed to update my driver, after I updated my driver to realtex I got the "you just plugged in a...
No audio input device found
Hey everyone, I am trying to get my mic to work, but when I hit "set up microphone" it says "No audio input device found". I have a High Definition Audio Device installed and the sound works fine. However, under the "recording" tab in Sound it says there are no audio devices installed and the...
Windows will not recognise microphone input from external sound device
Hi, I'm running Windows 7 Home N SP1 x64. I'm using an M-Audio Fast-Track Pro device to record audio into a music sequencer (Cubase 5), through a Shure SM58 Microphone. The M-Audio box is connected to the computer via USB. I've been using this set-up for about a year now and it hadn't caused me...
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
No Audio INPUT Device
I have an Asus P6T motherboard with Realtek ALC1200 on board audio and Windows 7 64 bit OS, DirectX 10, Audio Driver version 6.0.1.5859. The sound works normally for all audio functions. I installed Nero and went to use the Wave Editor application to record a song from the web and got the...
How do i fix my multimedia audio controller & pci input device driver?
My mobo is foxconn G31MV-K, Socket 775 Processor : Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz @2.00Ghz RAM : 1.00 GB OS : Windows 7 Ultimate 32-bit Audio: 5.1 HD audio by Realtek® ALC662-GR The main problem is the multimedia audio controller & pci input device in the device manager always...
