Windows 7: A few Creative Sound Blaster Z problems. (Sleep Mode, Front Ports)
03 Apr 2014   #1
Lukelbs
64 Bit Windows 7 Home
I have a few issues with my Sound Blaster Z card...
The first is that when my computer wakes up from sleep mode the sound stops functioning. In Foobar2000 I get this error message.
Unrecoverable playback error: A device attached to the system is not functioning. (0x8007001F)
I can't get any sound from the device but it still shows up in my device manager. When I restart my computer everything is normal and working again.
Second I'm not sure how to get it setup so that when I unplug my headphones from the front port the sound comes out of my monitor. I always have to change my default device in the control panel.
Any help would be great!
03 Apr 2014   #2
matts6887
Windows 7 ultimate 64-bit
Even though the device still shows up in the device manager; there still could be something causing some sort of glitch here. i would completely uninstall the sound blaster in the device manager; reboot; and reinstall the drivers using the disc that came with the sound card(if you have the disc) and then update the drivers and other sound blaster software if there are any updates available for it.
06 Apr 2014   #3
Lukelbs
Quote   Quote: Originally Posted by matts6887 View Post
Thanks for the response.
So I uninstalled the drivers and the software and re-installed in the order you said. Now instead of my device not functioning after sleep mode it will work but it asked me to select a new default device in my sound blaster software and in Foobar2k and I had to pick "Sound Blaster Z 2" which exists now instead of the original "Sound Blaster Z". My monitor is still silent too when I unplug from the front port.
10 Apr 2014   #4
Lukelbs
bump
15 Apr 2014   #5
Lukelbs
bump
17 Apr 2014   #6
kzaske
Greetings Lukelbs. Sleep mode issues with the Sound Blaster Z are well documented, they (creative) did release updated drivers that they claim should have fixed the issue, it didn't. The only work around is to actually restart the computer.
My advise it to download the latest driver and give it a shot: Creative Worldwide Support > Sound Blaster Z
As for the front panel issue; I was among the early adopters of Sound Blaster Z last May. It was the worse mistake I ever made. The card worked perfectly for about 15 minutes, then the driver caused a blue screen. That issue was corrected with a driver release but then the front panel no longer switched back and forth between my analog headset and analog speakers. They release two more drivers none fixed the issue. I spent over $80 in shipping for all four Sound Blaster Zs they sent me in addition to well over 250 hours trouble-shooting the issue before I finally upgraded to an older X-FI Titanium Fatality Pro. I have not reinstalled Windows since the last time I tried a SBZ, my front panel does the same as you have reported. In short: The front panel will not function correctly until you replace the SB Z with another card and reinstall windows.
Creative Sound Blaster 2 Z5 - Mic Not Functioning
I was trying to get my mic to work with a sound card called "Creative Sound Blaster 2 Z5" I updated all the software and the mic is seen by the software. I attach what setting I have right now. The sound is coming out my system mobo to my speakers and mic. My mic is get power via USB and has audio...
Creative Sound Blaster 5.1 live
Hi hope someone can help i am very new to this forum, at this moment i running XP Pro I want going to upgrade To Win 7 but it not recognise my Creative Soundblaster 5.1 sound card which is working fine under XP with all that i use i have been on web site to try & find driver for it. someone posted...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
creative sound blaster 5.1 vx
hei guys i just bought this sound card creative sound blaster 5.1 vx and bought a creative inspire 5.1 system now i have a windows 7 opertaing system and the sound card was not running so i went to the creative site and downloaded drivers from there and then installed them its installed and...
Well my Sound Blaster SB0460 X-FI Music Extreme wont work. Win 7 doesn't even see it. When I try to load the Vista drivers it said its not compatible with this operating system. Had the same STUPID problem with Vista until they released Vista specific drivers. Rich
Creative Sound Blaster 5.1 Live!
Hello all. After 2 weeks of trying to get driver for my SB 5.1 live! sound card,i did nothing then tapping in place... Ive tryed everything ive remembered to but i still cant find any solution. I know its an old sound card,but drivers must be here somewhere... Im using Win7 v.7600 RTM 64-Bit...
Drivers
