Windows 7: XtremeMusic PCI Card No Sound After Reboot
06 Apr 2014   #1
Raillex
Windows 7 Home 64bit
I've been experiencing a weird problem with my SB XtremeMusic card recently and am at wit's end trying to fix it.
About every fourth or fifth reboot, I lose sound. The card still appears in device manager (with Windows reporting the device status as working properly) and the speaker icon still appears in my taskbar as it always does. The "Sound" tab in Control Panel shows everything configured exactly as it was before the reboot, and yet the card will still not output sound. The card worked fine for a couple of years and only started acting up a couple of months ago.
Installing the latest and older Windows 7 drivers from Creative doesn't fix the problem, and the only way I've been able to get sound to output again is by uninstalling the card in device manager and letting Windows redetect the card and automatically reinstall the software. The card works fine for several boot cycles, and then inexplicably stops working again. I'm getting real tired of this uninstall/reinstall routine, and was wondering if anyone has a solution.
Thanks in advance for your help.
06 Apr 2014   #2
ICIT2LOL
Raillex I know you have probably tried but try reseating the card and look at my ditty here I mainly use for RAM slots but the same principle applies - before you reseat the card
SLOTCLEANING
Now as for the slotsto clean them use a strip of old credit card about 1/2 inch wide nip thecorners off one end - preferably round them offhold a piece of thin lint free clothover the end dab on some form of alcohol - iso propyl alcohol (what we swab theskin with before an injection) is good and GENTLYswipe along the slots.
This can also be donefor the GPU slot/s.
06 Apr 2014   #3
fireberd
Do you have the on-board (on the motherboard) Sound disabled in the BIOS? It needs to be disabled or there can be potential conflicts with other sound cards, and could potentiall cause the problem you are having
06 Apr 2014   #4
Raillex
ICit2lol - I did try reseating the card when this first started happening with no luck. I'm pretty sure the PCI slot was clean as I used an air compressor to clean out the dust from my mobo and wiped the gold fingers on the sound card with alcohol when this first started happening, but I'll try your credit card method and see what happens.
firebird - Yes, the on board sound is both disabled in bios and absent in device manager. The only other entry under "Sound, video and game controllers" is AMD High Definition Audio Device. My graphics card is an AMD HD 7870. You don't think there's some sort of conflict between the two, do you?
Edit: I disabled the AMD HDAD entry in Device Manager for kicks and we'll see what happens. I don't use the card's HDMI port anyway, so this would be a good trade off if it works.
06 Apr 2014   #5
fireberd
I doubt that the HDMI audio will affect it.
06 Apr 2014   #6
Raillex
You're right. It only made it worse. Disabling HDMI caused me to lose sound on every reboot instead of every third or fourth.
Still stumped.
06 Apr 2014   #7
fireberd
If disabling the HDMI audio caused loss of sound, there is some conflict. HDMI should have no affect on "Speakers" (the SoundBlaster). HDMI affecting sound with a PCIe sound card suggests some type of problem or conflict on the PCIe bus??
06 Apr 2014   #8
Raillex
That's exactly what I was thinking. However, Windows isn't reporting any resource conflicts after a "soundless" reboot. My mobo (an Asus M4A89GTD Pro/USB) only has one PCI slot, so switching the card to another slot isn't an option.
06 Apr 2014   #9
OvenMaster
Win7 Pro 32bit; Zorin OS 9 Core (in VM)
I had a similar problem about a year ago with my Diamond Xtreme 5.1 PCI card and two ASRock 880-GMLE mobos.
Out of the box, the first ASRock board would sometimes see the card and load drivers, other times, the sound would just stop and Device Manager wouldn't see the card. I RMA'd the mobo for an identical replacement. Everything went fine for 18 months until the problem started again. I swapped slots but that didn't help. I replaced the sound card and everything worked fine for one month until this problem again surfaced.
At that point my only option was to replace the mobo, so I put the Diamond card into a new Gigabyte board. No problems since June 2013.
07 Apr 2014   #10
fireberd
Aha! I see the issue (finally). You have a PCI sound card. The PCI slots on most new motherboards is not a true PCI slot, but merely a "bridged" PCI slot to the PCIe bus. Many PCI devices will either not work or not work correctly in a bridged PCI slot.
If you want to use a separate sound card, rather than the one built on the motherboard, best bet is a PCIe type sound card.
The bridged PCI slot is a major issue on the audio recording studio forums I visit.
factory sound card VS SoundBlaster USB sound card
hello in my present setup i have a factory soundcard thats installed in my intel atom mini pc and i have a usb soundblaster laying around.. my question is it worth to swapp in the usb sound card or its not much of a difference using the built in sound card my PC Cheap Intel Atom Mini Pc Hi10c...
Creative SoundBlaster X-Fi Xtrememusic... Again :(
Hi guys, I'm new here, but I've been reading the advice given here for quite some time now. Recently I installed Windows 7 Ultimate x64, and everything works fine - except Creative, of course :mad: My XtremeMusic card doesn't work at all. And let me assure you: I have tried EVERY single...
reboot loop after instaling sound card
i had instaled windows 7 ulimate on my PC which had pentium4 on it after i instaled SoundBlasterAudigy from windows update my PC reboot by itself:cry: even after i turn off "automatically restart" option, my pc still restarted by itself please help me o resolve this...
FPS drop because of sound card / sound card drivers?
I've recently upgraded my os to windows 7, and noticed a significant fps drop in all games I've installed. The problem seems to come from the sound card. I've disabled it in device manager and I gained a steady 15-20 more in most of the applications. Any idea what to do? Is it a driver issue or...
Gaming
X-Fi XtremeMusic stereo flipping
Running Windows 7 x64, build 7100. My Creative X-Fi XtremeMusic will randomly swap stereo channels on reboot. This is using the digital output to an external DAC. Luckily, I can just reverse the rca plugs in the back of the DAC to compensate, but it's annoying. The reversal is system-wide...
X-Fi XtremeMusic hisses, crackles and pops
Ok, weird problem here - I've got a Creative X-Fi XtremeMusic and Win7 will detect it, and I've installed the latest drivers (2.18.0008?). When it first installs, things are fine. I get sound through iTunes and System sounds. But after the first reboot, it hisses and crackles and pops. ...
