Windows 7: "Scan for Hardware Changes" fixes audio problem, but problem returns
06 Apr 2014   #1
Chappter31
Windows 7 Home Premium, 32 Bit
Hi all,
Issue: The sound on my internal laptop speakers does not work when I try to play audio.
Solution:
However, if I go into "Device Manager" and click "Scan for Hardware Changes" on the "Sounds, video and game controllers" section, my sound returns instantly. The moment I click "Scan..." the sound appears straight away and plays back without issue.
The Problem:
Problem is, while the sound plays back fine as long as I am playing sound, the problem of no sound returns once I stop audio payback. I've noticed I can stop playback and the sound will still play back for a minute or two, but if I don't play audio for longer than about 5 minutes the sound again disappears next time I try to play back and I have to do the "Scan..." thing again to get it working. It's as though my system keeps defaulting back to an incorrect setting or something after a few minutes.
External Speakers: There is no problem at all when I have my (bluetooth) external speakers selected. Sound plays through them fine.
What I've tried to fix:
- Troubleshoot both "Playback Audio" and "Hardware and Devices" through Control Panel, but neither fixes issue
- Update Driver Software for my "Conexant High Definition SmartAudio HD2", but it says I'm up to date
- Read the forums to find my specific problem, but couldn't...apologies if I've missed it.
From Speccy > Audio
- Sound Cards
Bluetooth Hands-free Audio
Bluetooth Stereo Audio
- Playback Devices
Speakers (Conexant High Definition SmartAudio HD2) (default)
SPDIF Interface (Conexant High Definition SmartAudio HD2)
From Speccy > General
Operating System
Windows 7 Home Premium 32-bit SP1
Intel Mobile Core 2 Duo T5200 @ 1.60GHz 69 C
Merom 65nm Technology
RAM
4.00GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
TOSHIBA Satellite P100 (U2E1) 70 C
Graphics
Generic PnP Monitor (1440x900@59Hz)
Intel Mobile Intel 945 Express Chipset Family (Toshiba)
Storage
93GB TOSHIBA MK1032GSX ATA Device (SATA) 39 C
Optical Drives
MATSHITA DVD-RAM UJ-850S ATA Device
Audio
I hope that's as much information as you guys need to help me. Advice much appreciated.
Thanks.
06 Apr 2014   #2
fireberd
Please post a screen shot of the Device Manager/Sounds section.
06 Apr 2014   #3
Chappter31
Hi Fireberd,
Screen shot of the Device Manager/Sounds section as requested:
"Scan for Hardware Changes" fixes audio problem, but problem returns-dev-audio.png
06 Apr 2014   #4
fireberd
The Bluetooth is suspect. What shows up in the Control Panel/Hardware and Sound and finally the Sound panel playback? If it is setting the Bluetooth as the default Playback device, the speakers will not work.
06 Apr 2014   #5
Chappter31
Screenshot when BT is off:
"Scan for Hardware Changes" fixes audio problem, but problem returns-play.png
And when BT speakers are switched on:
"Scan for Hardware Changes" fixes audio problem, but problem returns-play-2.png
06 Apr 2014   #6
fireberd
Do this, if there is any Windows corruption with the Conexant HD Audio it will fix it.
Go to the Device Manager, RIGHT click on the Conexant entry and then LEFT click "Uninstall". DO NOT check the box to also uninstall the drivers Restart the PC and when Windows starts it will detect and reinstall the Conexant. This fixes a lot of flakey problems.
07 Apr 2014   #7
Chappter31
I tried this last night - Windows didn't re-install the Conexant when I re-started my computer, but I ran a manual Windows Update and that re-installed Conexant, although it didn't fix the sound problem.
I then gave your suggestion a second try...but again Windows didn't re-install the Conexant automatically and when I tried to do it manually it didn't find any updates that way either.
Now, the sound icon in my tray is showing "No Audio Output Devices Installed", with a red cross over the icon. When I re-start computer, it doesn't seem to recognise that the component is missing. Troubleshooting "Sound Problems" doesn't re-install/fix it either.
Ugh, not sure what's going on...
07 Apr 2014   #8
ComputerGeek
Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
  1. Look in Programs and Features, see if Conexant audio entry. If yes, uninstall it from there
  2. Go to the Toshiba support and use the driver you find from Toshiba for your specific model
  3. When BT installed (see your 2nd screen shot) note you must set speakers back to default device for them to output sound (in your screen shot BT is default)
  4. Ctl Pnl->Sounds. Right click the speakers. Select Advanced tab. Make sure exclusive mode is turned off
  5. If you still have a red X, go to DevMgr, right click the audio driver->Properties->General tab. Under Device Status what's the numeric code?
08 Apr 2014   #9
Chappter31
Hi ComputerGeek - thanks for your input.
My red X is gone after I performed a Manual Windows Update, so I guess the system eventually found the missing componant.
On my original issue, the reason I chose the thread title "Scan for Hardware Changes" fixes audio... was because I thought it might be possible to infer something from that fix. In other words, if "Scan for Hardware Changes" is the solution, perhaps we could work back to identify the problem?
I'm not a PC guy, but it seems to me that the computer has all the components it needs to play sound, but for some reason it keeps on defaulting back to a state that doesn't recognise some kind of hardware change/configuration that I instead need to manually prompt it to search for. As I mentioned, clicking "Scan for Hardware Changes" restores the sound the instant I click that option and the box appears saying "Scanning Plug and Play Compliant Hardware".
I could be on totally the wrong track there, but I'll throw it out there.
Thanks.
08 Apr 2014   #10
ComputerGeek
Quote:
I'm not a PC guy<snip>
You may not be a computer guy, but you sure think like one!
Disconnect or disable BT. I don't BT as an audio option during these tests. Also, I'm assuming your audio driver is installed - whether it's working or not, as long as it's installed. Do the following
  1. Click Start. In the search box type dxdiag. Hit enter
    • If you are running 64-bit Windows, you'll see a 64bit Dxdiag button at the bottom of the window
    • Click it to generate a 64bit dxdiag report
    • Now click the Save All Information button, save as a text file, and upload the report to next post
  2. Right click the audio device in DevMgr->Properties->Details. Scroll down and look for Upper and Lower Class Filters (see pic below)
    • If one or other doesn't exist for the device, you may not see an entry. But if either exist in the pull down menu, select them. Then copy/paste what you see for each
You can probably only do the following when the driver is installed and there's no device error in DevMgr
> Verify your speakers are the default device
> Turn off exclusive mode on your speakers. (See my post #8)
&quot;Scan for Hardware Changes&quot; fixes audio problem, but problem returns-filters.jpg
Realtek HD Audio Problem: Headphones appear as "Speakers"
Dear all, my speakers do work. When i plug in my headphone at front the speakers get replaced, means I head everything through the headphone. Headphones themselves aint shown under "Sound": It appears that both, speakers and headphones are used as one source for audio-out. However, I...
How to fix "not responding" problem in all programs and "lost updates"
It's been a month since my laptop gone wrong. All programs doesn't run properly, and stop working many times. Media Player, Office, Internet explorer, all stop working frequently, and I have to wait ten second until five minutes to continue my work. Two days ago I noticed that when I downloaded...
Performance & Maintenance
System will rarely post. "Unknown" Hardware problem
-This is a repost, as last time i only had a single response, and no replies after that- Hello once again Sevenforums. For the last few days, i have had a rather frustrating problem with my system. It doesnt want to POST. Let me explain this; Turning the computer on is a mystery. The...
Hardware & Devices
Strange "directional" audio problem
Hello, I just created this account as soon as I remembered there were W7 forums :) My problem is: In many games like Mount & Blade Warband, and Morrowind (yes, I still play it) I started to notice an issue with my sound: Voice audio, and other sfx audio like footsteps only work when the source...
"Audio output device not installed", code 10, presario v3020US problem
Hello all! So, I've just installed a fresh version of Windows 7, coming from Ubuntu 10.04. Everything seems to work smoothly, except for the little problem of having NO SOUND! I've tried everything I can think of or find anywhere on the internet, and nothing seems to be making any difference....
What hardware problem is it if the rotating "translucent window" slows
What hardware problem is it if the rotating and splitting "translucent window", which is at the top right corner of the file transfer window, slows down from its original speed? It shouldn't slow down even if the file transfer speed is slow, should it?
Hardware & Devices
