Windows 7: Weird sound card problem
27 Oct 2009   #1
I'm using an audigy 2 zs, just updated the sound card by downloading from creativelab. I have a problem with the card in windows 7 though:
I like to get the treble all the way up, and the bass up a bit, it makes things sound alot nicer. But, everytime I do this, the voices of characters when I watch DVDs or play video games become really low, everything else sounds great though, its just dialogue between characters thats just so low you have to put your ear right next to the speakers to hear them or something, then music from the background is blasting loudly in my ear...the treble and bass setting never gets properly saved also, everything I restart the computer, they get reset.
anyone else experiencing the same problem? It was like this in the beta for me also...
28 Oct 2009   #2
7600.20510 x86
You're having 5.1 difficulties. Or you are only using 2 speakers when the sound output needs 6 of them for how you have it set currently.
Check the settings in the driver's app for that. There are users with Creative gear. They could guide you or suggest an alternate driver.
28 Oct 2009   #3
I'm using 5.1 speakers. I don't have the center plugged in though. I notice that when I click the "test" button to test individual speakers, it is the rear 2 speakers that are kinda of "mute" and where the dialogues come from.
I found a setting for creative speakers that lets me move the sounds from the rear to the front speakers, and that fixed the problem I guess...I'm thinking this probably doesn't make the sound as good though compared to being able to hear rear speaker noises from the rear speakers where they are supposed to be coming from...
Search this Thread:
Advanced Search
Having a weird problem with my Graphics Card
Hello guys. It's been a long time since I last used my desktop computer because I moved to another country and I wasn't able to bring it. Now my mom asked me to fixed it so that my sister can use it. I'm just having a weird problem with the display because sometimes the screen will go black for a...
Graphic Cards
a weird problem with sound on my laptop
I have a very weird problem with my laptop i have a SAMSUNG ATIV BOOK2 laptop , i bought it like two weeks ago , and i have this weird problem on it .... sometimes when i turn the laptop on , the speakers just dont work , and i have to restart the computer , i even sometimes have to plug it off...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: The problem was that the volume levels were off, and...
Problem with sound card
Have just done anew build and installed an Asus Xonar DG sound card in this afternoon -just like in my Sandy Bridge build. Now I have tried installing the driver but it goes half way and then stops with the message in the pic and I have no idea what this is about. Never happened on the...
Problem with DIAMOND XS 5.1/16 bit Sound Card
Hello there I have DIAMOND XtremeSound 5.1/16 bit Sound Card and I am using Windows 7 Ultimate 64bit , overall I like it but I have a very small issue. I am getting sound only from one outlet/inlet Sound card have 3 outlet - Pink - Black and Green Sub have 3 cables - Pink - Black and Green...
problem with sound card
hi to all i recently updated my pc to asus p6x58d premium intel i7 950 corsair 2x3 gb ram triple channel 2000 mhz power 900 watt acbel gtx 295 vga 3 sound cards: electronic konnekt 8 external sound card connect with pc via firewire(i must use it for music making) 2.creative xfi xtreme...
