Windows 7: Sound low, even when maxxed out.
14 Apr 2014   #1
iTyphlosion
Windows 7 x64
Okay, so my sound is low, even when the sound slider is maxxed out. I have checked my mixer, and everything is maxxed but no dice. Sound is low with anything (Youtube, Spotify, a game, etc). The sound is just all around low. This occurs when I use my Steelseries Siberia Elites, or any other headphones. When I use my external speakers, though, the volume can go loud because, well... speakers.
14 Apr 2014   #2
fireberd
Do you have the RealTek sound drivers, from Gigabyte? or do you have the generic, basic function Windows installed HD Audio Codec for the sound driver? If you only have the HD Audio Codec, install the correct RealTek driver and see if that changes anything.
Do you have an standard analog headset you can use? USB headsets do not use all the headset output functions that analog headsets do.
Can you plug your speakers into the front panel headset jack? for testing to see how loud that is.
16 Apr 2014   #3
iTyphlosion
Windows 7 x64
Yes, I have the Realtek Drivers fully updated. I believe I have a standard analog headset. I am not the most informed on what most of this stuff means, but I do have headphones that plug into the headphone jack and not into an external soundcard like my Elites. I guess it has to do with not using all of the output functions, because when I unplug my elites from the usb soundcard and instead use a plug that came with them allowing me to plug it into the jack, the sound is louder.
So am I SOL when it comes to the sound while using this headset? It's a bit disappointing, because the soundcard allows for a custom engine to be used with the headset, as well as utilising some of its features.
16 Apr 2014   #4
HoneycombAG
Did you think of checking the playback options?
16 Apr 2014   #5
iTyphlosion
Windows 7 x64
I have tried that. It didn't make much of a difference, and the sound was still way too bloody low for my liking. Playing Skyrim is unbearable with the low sound, even after using the Loudness Equalisation.
16 Apr 2014   #6
Layback Bear
Windows 7 Pro. 64/SP-1
This may or may not help.
Start Orb and type in Audio and see if you have a Audio Manager. If you do, tick on it and see if you can find what you want.
16 Apr 2014   #7
iTyphlosion
Windows 7 x64
What exactly is Orb? I don't seem to have it, or I am not looking correctly.
16 Apr 2014   #8
Layback Bear
The Start Orb (button) is that little circle far left on the Taskbar with the Windows flag.
16 Apr 2014   #9
iTyphlosion
Windows 7 x64
Ah. Yeah, I have Realtek. Although the settings only really apply to my speakers and not my headsets which are having the issue of not enough sound. There is a sound manager as well for my headphones (Steelseries Engine 3) and I have checked that as well. Sound is full and I have the EQ on Explosion for more sound, but sound is still low.
16 Apr 2014   #10
iTyphlosion
Windows 7 x64
And it isn't an issue with the headphones themselves being broken or anything, as they blast when I am using them on my phone.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
