Windows 7: rear channel audio issues
18 Apr 2014   #1
lornedh
windows 7 64 bit
i have a sabertooth 990fx r2 mother board with a Creative® Inspire M5300 - 5.1 Channel Speaker System
Today My auxiliary rear black cable's tip broke off inside my rear black auxiliary jack
I used a metal skewer to try to get it out finally i used a ink cartridge from a pen to get it out
i used a dab of glue to glue the tip back on the black auxiliary jack
after a hour or 2 of drying i plugged in my 5.1 audio cables into my 8 channel rear audio ports and all my speakers work except the rear left one my rear right one works fine i switched the speakers to see if it was them but it wasn't.
Do you think my audio port on my mother board is broken from me trying to get the tip out cause only one rear speaker is getting sound the other rear speaker works fine and it uses the same black optical port
or do you think its just the speakers since the rear optical tip broke off and i had to glue it back on the tip fell off again and i plugged it in with the tip missing off the black rear audio cable with the same results
im worried which part is broken hopefully its the speakers
could the tip breaking off the black rear auxiliary 3.5 mm jack cause this issue im not sure what its purpose even is
18 Apr 2014   #2
fireberd
It is most likely the plug that you fixed. Gluing back on probably is not making electrical contact. You will have to replace the plug.
Realtek HD Audio No Rear Sound
I have a problem with the Realtek HD Audio. I just installed Windows 7, and configured my audio settings for all my 4 speakers, 2 front and 2 rear. The test was successful, from Realtek HD Audio Manager. But I was just playing a song on iTunes and there was no sound coming from the rear speakers....
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Audio Only out of one channel (multiple headsets and audio devices)
I have three audio devices on my pc (ATI HDMI, Via HD onboard and steelseries usb soundcard) and through all devices I only get audio out of the left channel. I have tried two pairs on headphones and my tv speakers all with the same results. I have looked at all the balancing end everything is set...
4.1 audio only coming out of rear right speaker
As above. I have a 4.1 surround system that I've been told can work with just the 3 port motherboard sound (red-green-blue ports), but the only sounds are coming out of the rear right speaker. Which is still screwy because it's activating RR when it should be coming out of RL. I believe I...
No audio from rear jack & no hdmi audio
hi guys pretty new here so take it easy plz (lol) i have 2 problems regarding audio. 1. when i upgraded my pc i added a okish motherboard but i wanted sound from my front panel so i took the jumper cap off the prongs for audio but now i have added some desktop speakers and want to plug them...
Graphic Cards
