Windows 7: Difference between Audio Cable and Aux Cable
21 Apr 2014   #1
boogieboy
Hello I have a quick question! what is the difference between Audio Cable and Aux Cable? Is there any difference in sound quality or in Left Right Channel Sound? I'm asking because I recently bought Edifier C2 2.1ch Sound System for my PC that has an External Amplifier that has Aux Input as well. Reason is I'm asking coz I want to hookup my PS3 with it as well that through the Audio Cable as PS3 sound output isn't working on the Aux but I primarily use this audio system with my PC as I use it more frequently.. so was wondering to hook the PC with Aux and PS3 on the Audio input.
21 Apr 2014   #2
fireberd
Depends on what type of audio signal you are dealing with. Low level audio should use "shielded" audio cable. Speaker links can use "speaker" cable.
21 Apr 2014   #3
boogieboy
I'm using both good quality cables... I bought a Aux cable for $2 today and the audio cable comes with the Edifier C2 and PS3 has it's own original cables too
22 Apr 2014   #4
fireberd
I'm an ex-guitar amp tech and electronics tech but still not sure what you have or what you are calling what.
Any difference in Sata2 or Sata3 HDD cable
Have a system with Sata3 capable MB interface and new Sata 3 drive. Are cables used originally on Sata2 systems OK to use on the new Sata3 MB & HDD...any performance difference between the two cables when used on new Sata3 components ? Thanks
Hardware & Devices
hdmi cable to LG tv no audio
hi, i have my pc connected to a LG flatron 22" tv by hdmi cable the picture is fine but the audio does not play through the tv, a jack cable from the pc to the tv does not work either, if i use the jack plug into separate speakers it will play the audio through the speakers. i have checked in...
Will this cable work to extend coaxial cable for cable box?
Getting a new TV and placing it in a different spot than where the old TV is and I realized the coaxial cable coming from the wall isn't going to reach the new location for cable box's "Cable IN" connection. Can I use this as an extension? It looks right to me but I just want to be sure.
Chillout Room
Digital Cable Advisor fails, can't install cable card. . . why?
http://img198.imageshack.us/img198/83/cableadvisor.png Uploaded with ImageShack.us http://img51.imageshack.us/img51/4821/playreadfail.png Uploaded with ImageShack.us HD Radeon 6870 Graphics card
Media Center
Network Cable Unplugged error: cable is plugged in
Hello, Since last night, my LAN connection has been giving me the error "Network cable unplugged." I have tried swapping the cable with another, swapping the ports on the router, restarting the router, power cycling the router, turning off the router and my computer and then turning them back...
Network & Sharing
Network cable unplugged message when using ethernet cable
Hi, I have a brand new Dell Precision Workstation with Windows 7 Professional 64 bit. I have not been able to connect to networks or the internet. It does not recognize that it is plugged into the network/internet via an ethernet cable. The computer has a Broadcom NetLink Gigabit Ethernet adapter...
Network & Sharing
