Windows 7: PC to Home Theatre HDMI Audio problem
28 Oct 2009   #1
Windows 7 64-bit
I have PC connected to a 22in TV via DVI, and I have the HDMI connected to a home theatre system shown below...
Discount Grundig Grundig GUHTS21 2.1 Channel Home Cinema HDMI, Divx DVD & Home Cinema from Cdiscount.co.uk
The sound system has a HDMI port so instead of playing the audio from my PC through the 3.5mm jack (poor quality) I wanted to play the audio through the HDMI cable.
However, when I connect it via HDMI and go to control panel>sound it shows a red arrow saying "not connected".
My graphics card is an integrated radion 4200.
Any ideas?
Steve
28 Oct 2009   #2
7600.20510 x86
Check the HDMI cable for defects. Use a different one if you can somehow, to test.
Could be that the driver isn't working so well or something of that nature.
28 Oct 2009   #3
Windows 7 64-bit
I was originally using the HDMI cable to connect the PC to the TV and it worked fine...
28 Oct 2009   #4
Win 7 Ultimate x64
Etobicoke, Ontario
From the link you posted to your HTIB,
Quote:
Key Features
Model Number GUHTS21
Dolby Digital Yes
Audio Power Output (RMS) Total Output Power: 300 Watts (RMS)
Speakers Included Yes
DVD Recorder DVD Player DIVX Yes
MP3 Playback Yes
HDMI Output HDMI Connection with up Conversion
2.1 Channel Media System Yes
Dolby Pro Logic II Yes
don't see anything there saying that the HDMI is for input, output only. If there isn't a HDMI in connection (and there doesn't appear to be), then you will never get audio in over HDMI.
28 Oct 2009   #5
7600.20510 x86
Awesome, Stormy. Good catch. +rep
28 Oct 2009   #6
Windows 7 64-bit
I assumed that as the audio system has a hdmi port, audio could be sent from my pc to the system. I assumed this because if I connect my tv to the audio system via hdmi it will play audio from the tv through the system...
28 Oct 2009   #7
Win 7 Ultimate x64
Etobicoke, Ontario
Nope, that isn't how it works; that HDMI port is output only. The system is processing/playing the audio all internally. To get audio in over HDMI the system needs to have a HDMI in port.
28 Oct 2009   #8
Windows 7 64-bit
Quote   Quote: Originally Posted by stormy13 View Post
ok thanks for clearing that up!
 PC to Home Theatre HDMI Audio problem problems?
Similar help and support threads for: PC to Home Theatre HDMI Audio problem
Need help DLNA and LG Home Theatre Network & Sharing
Connecting PC to TV and home theatre system Music, Pictures & Video
Need help connecting home theatre system to my pc Hardware & Devices
HDMI audio problem when connecting LCD TV to PC via HDMI Sound & Audio
Post a Haiku on Twitter; win Xbox 360, home theatre sys News
