Windows 7: Baffling audio problem in Chrome
28 Apr 2014   #11
ICIT2LOL
Quote   Quote: Originally Posted by Layback Bear View Post
I would not change a bunch of things on a computer over a couple of youtube channels. If your system works as it should except for the youtube channels I would blame the youtube channels not your system.
I suppose you could end up chasing your tail with this one. Personally I run an Asus Xonar DG card and the GUI is real beauty for what I want.
28 May 2014   #12
Plockets
I did figure this out finally, once I realized the problem only happened with youtube videos that were using the HTML5 player. A Google search suggested changing my speaker configuration, and once I changed it from 5.1 to 2.1 the problem went away.
Baffling Chrome issue: almost all EXE's cannot be downloaded
This problem has me utterly and completely baffled. I first turned to the Chrome forum, but it's tumbleweeds there. Still, here's the thread: I can't download anything with Google Chrome redux - Google Chrome Help I'll adapt that for this forum in the hope that someone can help me "think...
Browsers & Mail
Audio works in Firefox but not in Chrome
Reinstalled Win7 after a disk drive failed. Everything seems to work fine except the audio. It's weird. Play a YouTube video in Chrome - silence. Play the same video in Firefox - works great. Play an RPG - no background music but the ambient sounds (footsteps, combat noises) play normally. ...
Baffling intermittent mouse lag problem Razer Abyssus
I have searched help forums far and wide without finding a solution to this problem, or even a similar description. Every 10 minutes or so, my mouse will lag for 4-7 seconds, and then correct itself. What I mean by lag is that it will suddenly appear to me moving more slowly than before, but will...
General Discussion
Google Chrome - No Audio with Flash Player
I have recently found that Chrome doesn't play audio with Flash, it works with HTML5. I have researched into this and people say disable all but the latest flash plugin but I only have one, re-install Chrome and re-install sound drivers. None have worked apart from changing my sound from...
Browsers & Mail
Audio problems in Google Chrome/Firefox/Ie...
Hi there. Yesterday everything was fine, sound was working perfectly on Windows and on Youtube etc. However today when I came onto my computer I realised that the sound on the computer still worked, i.e, start up sound, wmp, itunes and VLC, but when I went onto the internet none of the sounds...
Random BSODs that are baffling - Occur at any time
Hi all, I have completely random BSODs, they occur at any time, idle or doing something. It can run for 11 hours, randomley crash then crash 5 times in a row. I have tried many fixes, those that I can remember I will post: At first about 7 months ago I built this pc, everything worked fine...
BSOD Help and Support
