Realtek AC'97 Audio (Code 39)
CompCare
8:08 PM
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39).
So as you can see above, i have tryed everything to fix this. I get this message or the computer crashs and i have to do a system restore.
If you have any ideas i didnt think of let me know.
Microsoft Trusted Audio Drivers
I have the same troubles with my creative sound blaster Audigy SE and incorporated sound C-Media 6501 on Windows 7:cry::cry::cry:. If anybody can fix this problems please let me know.
Best regards, Andre1:huh:
Windows XP SP3
Windows XP SP3
Yea, same problem here guys.... did any of you do an MS update recently??
XP/win7 x86 build 7127Athlon64 X2 DUAL 4200+ 2.21ghz2GB Dual Chan DDR2 CorsairNvidia 6800GT
CUSTOM
ASUS K8 PRO SLI
Nvidia 6800GT
nvidia
19' LCD
1280x1024
WD 250, 2x500, 2x1TB IDE/USB
WD 250 SATA (system)
SEAGATE 120 Sata
coolermaster 450
SUPERFLOWER
1 HDD bay fan, 5x80mm Case Fans, AEROGATE II Fan/Temp
MS wireless
MS Wireless
fassssssssst
or have MS office 07 installed by chance?
CUSTOM
ASUS K8 PRO SLI
Nvidia 6800GT
nvidia
19' LCD
1280x1024
SEAGATE 120 Sata
coolermaster 450
SUPERFLOWER
MS wireless
MS Wireless
fassssssssst
No MS Office 07 was installed. I just install Windows 7 and driver for Video & Motherboard.
Windows XP SP3
Windows XP SP3
Pad, try this link and install these drivers if you are on x86.... also supposed to work with x64, but I have only had it working/tested with x86, until now... :(
but i had the same problem after I installed 7. It worked fine at first, went to updates and got the problem. Used these drivers in the link and got it working again. My dummy self of course updated some MS (office and win defender) last night only to find that my audio had failed on me again.
Here's the link: Realtek
also what motherboard do you have (chipset)? and what platform of win7 are you running?
Realtek
CUSTOM
ASUS K8 PRO SLI
Nvidia 6800GT
nvidia
19' LCD
1280x1024
SEAGATE 120 Sata
coolermaster 450
SUPERFLOWER
MS wireless
MS Wireless
fassssssssst
My platforms is following:
Motherboard - Asus M2NE-SLI (NForec 500 SLI)
Graphics adapter - G-Force 9600 GT (512Mb/256bit)
RAM - 1Gb DDR II 667 Mhz (RAM is from two differed producers)
HDD - Samsung 160 Gb
Sound - Creative Sounb Blaster Audigy SE 7.1
I had tried english Windows 7 32 bit
Windows XP SP3
Windows XP SP3
ahhh.... you in wrong thread Pad.... thought you had realtek.... i dont know for your creative card, sorry
CUSTOM
ASUS K8 PRO SLI
Nvidia 6800GT
nvidia
19' LCD
1280x1024
SEAGATE 120 Sata
coolermaster 450
SUPERFLOWER
MS wireless
MS Wireless
fassssssssst
I know that it is thread for Realtek, but i have the same trouble as you. I had tried any available drivers for my creative sound blaster and in each time a get error code 39. The same is reproduced for incorporated sound C-Media. :((
Windows XP SP3
Windows XP SP3
I don't know what else can I do?
Windows XP SP3
Windows XP SP3
well i seemed to have fixed my problem for now... i used my old cd for motherboard that had my audio (realtek) drivers on there. Old cd, old version of realtek, file version 2.1.5 :eek but its working ... compat mode vista
maybe try using older drivers (cd) with comp mode vista?
[edit] driver version 5.10.0.6010 installed with audio codec ALC850
Reports nvidia audio controller(0059) ... maybe this could be the conflict with many of us....
CUSTOM
ASUS K8 PRO SLI
Nvidia 6800GT
nvidia
19' LCD
1280x1024
SEAGATE 120 Sata
coolermaster 450
SUPERFLOWER
MS wireless
MS Wireless
fassssssssst
Yes, i have tried and drivers for Vista from old CD. But i have not tried drivers for XP. Maybe this can help me, I don't know. When it will be done a post an reply. Thanks for support :)
Windows XP SP3
Windows XP SP3
code error 39 driver hl dt st dvdram gsa t50f
can anyone help me get this driver????????/
vista home premium
vista home premium
Win 7 won't load sound blaster or ATI graphic drivers
Win 7 Won't use Audigy drivers error 39. Won't load ATI graphic drivers,latest drivers are only for XP & Vista no drivers available for Win 7:mad:. Had enough of trying to use Win 7.REINSTALLED XP. now machine is OK. :confused::(:mad:
xp
xp
Issue realtek ac97(driver rel. 6505), win 7, error 39
Did anyone fix issues about ac97? I've got it but realtek driver 6505 for win 7 doesn't work properly, error 39 appears!!
Thx
Tom
win 7 ultimate
win 7 ultimate
