Windows 7: sound card increace volume?
24 Apr 2014   #1
soulfood
XP windows Professional
hi will a sound card increase the volume of my computer? (for example, The asus xonar dsx pcie or a creatve one model) thanks
24 Apr 2014   #2
fireberd
Generally, no. The sound card only provides a standard output signal that is used by "amplified" speaker systems. The volume level is controlled by your speakers.
Same way with the headphone volume, a set (standard) output is used for analog headsets.
24 Apr 2014   #3
NoN
Quote   Quote: Originally Posted by soulfood View Post
Guess you'll need a sound system with an added soundcard otherwise it will be a waste!
But if you already have a Kit, yes it could be better sound with a PCI-e Sound card (if you don't want the stock motherboard one).
You can increase your actual overall sound output by using in the sound parameters "loudness equalization" also.
how do I increase my volume even more?
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Volume Control wont move sound card slider
I have E-MU 1212M sound card, Windows 7 and I can't fix this problem which I haven't had before. I reinstalled the Windows 7 and now I can't move my Volume Control and affect my sound card volume. My sound card volume wont move until I move it. It's like my volume mixer is pre-effected,before my...
Creative sound card, windows 7 compatible volume control?
I recently bought a dell computer second-hand from my friend, who had XP installed on it. It came with a subwoofer and a set of 4 regular speakers. On it, he had installed a form of creative volume control in addition to windows volume. The way it worked was he had the windows volume set to 100%...
New Sound Blaster 5.1 VX card crackling and low volume...
I've had my new sound card for over a week now, and I've had constant problems with the sound since then. It's better than the complete lack of sound I had before, but now it's starting to get on my nerves. My SB 5.1 VX card constantly makes crackling noises when in windows and other audio is...
Rocketfish 5.1 Surround Sound Card / Volume issues
Hello, I been using the Rocketfish 5.1 surround sound card for quite some time now, and just last month or so it just stoped working if I dont use the matrix mode all the speakers work. But I constantly have to turn the levels of each speaker up in the sound settings and when I do that it max's out...
X-Fi Sound Card issue ( Volume Fluctuation ) in windows
I was playing wolfenstein and every now and then the volume would increase in one go which made me http://www.rage3d.com/board/images/smilies/eek.gifhttp://www.rage3d.com/board/images/smilies/eek.gif. Now it's doing it with music too , every now and then the volume would shoot up didn't happen in...
