Windows 7: Distortion sound using onboard realtek sound card on windows 7ultimate
29 Apr 2014   #1
samoila
windows 7 ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd quality)!What should i do,there is a fix,something?On windows xp i had NO PROBLEMS!
29 Apr 2014   #2
fireberd
This is an older motherboard. The RealTek is Realtek® ALC662
Have you tried the driver from RealTek? The "AC'97" Codecs are the ones to use.
Realtek
29 Apr 2014   #3
samoila
windows 7 ultimate
I try also with the ac97 realtek drivers but the same result!
29 Apr 2014   #4
fireberd
I have a recording studio. What kind of "distortions" are you getting?
According to the Foxconn specifications, 2GB is maximum memory. That is bare minimum for Windows 7 32 bit OS. Maybe memory is an issue? Some older Windows XP hardware is not really a good candidate for Windows 7.
29 Apr 2014   #5
samoila
windows 7 ultimate
I guess the right word in english is crackling sound,i had 2gb of memory,amd le1150 2ghz procesor!I nottice that the sound is more distorted when i move my usb mouse or the worktable by tapping the keyboard,but on windows xp with the same hardware configuration and drivers i receive nothing!This annoying sound appers even i`m wathing youtube vids or playing a movie on bsplayer!
29 Apr 2014   #6
fireberd
Popping and crackling is a problem that has been reported many times on here. There is no "one fix" for the problem. Some items that have been known to cause this is sound and video drivers, Wi-Fi connections and even defective power supply.
29 Apr 2014   #7
samoila
windows 7 ultimate
grrr,i try using skype to talk with my aunt and i resist only 5 min because the sound issue!i think i will return to xp
29 Apr 2014   #8
fireberd
Unfortunately, some older hardware is not really a good candidate for Windows 7. I'm seeing many problems with older hardware that has been upgraded to Win 7 or Win 8 on different forums.
29 Apr 2014   #9
samoila
windows 7 ultimate
one question i had-is linux a good solution because i want to download it or came back to xp!
29 Apr 2014   #10
fireberd
Linux is a possibility. Try it and see what happens.
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
Realtek onboard sound card with 5.1 surround speaker fill problem
I recently installed a new motherboard Asus Sabertooth 990FX. It has an on-board sound card "Realtek® ALC 892 8-Channel High Definition Audio CODEC". I'm using 5.1 surround speakers from creative. Speaker fill with windows update driver, or Realteks driver from Asus' website, has the same outcome. ...
Realtek onboard sound. No sound
I don't know how to title this too well but yeah. I have been using a USB headset for quite some time but I recently purchased some Audio Technica ADH-700's. I've plugged them in and woolah!.. Just kidding.. No sound at all :( I have an Avermedia Live Gamer HD Capture Card and with getting it...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Realtek onboard sound card: Static/Crackling noises
Hey, I recent put together this new rig. I'm using the onboard sound card for my Gigabyte GA-X58A-UD3R Rev 2.0 mobo. The sound chipset is Realtek ALC889. I've updated the latest drivers, but there is crackling/static noise when I play music. Currently I mainly use a 2.1 speaker system. But...
Enabling onboard sound with a sound card
Hi, I fly MS FSX and I want to be able to chat to ATC with my headphones and then hear the engine noises coming out of my speakers and sub-woofer. I have a soundcard and my motherboard has onboard sound. I can't find the bios setting to turn it on and I can't see any hint of it anywhere on the...
