Windows 7: Sound card problem - headphones work, notebook speakers don't
30 Apr 2014   #1
sunsetlover
Win 7 Ultimate 32-bit
Hi all,
I just bought an old Toshiba A210 laptop and I'm dealing with a couple of (minor) problems. As the title says, I've tried every conceivable control, I can't get any sound from the speakers. No hissing sound, nothing, completely silent. Headphones work fine though.
I checked device manager and drivers, it's a Realtek driver, I went to Toshiba and saw that I have the latest driver for Win 7.
Any ideas what kind of problem this is? hardware probably?
This laptop had Win 7 Ultimate installed over Vista.
I probably need to try some nice USB speakers anyway though
Thanks!
30 Apr 2014   #2
fireberd
Considering its a used laptop, it wouldn't surprise me that one of the reasons it was being sold is the speaker problem.
30 Apr 2014   #3
sunsetlover
Yes, but I knew about this problem when I bought it.
30 Apr 2014   #4
fireberd
Open the case and see if the connector has just come loose for the internal speakers. Usually the headphone jack assembly is a separate small board and sometimes the speakers are connected there.
No speakers or headphones are plugged in - Windows 7 Sound Problem
Hi All, First time poster and only limited self taught knowledge. Any help is greatly appreciated as have spent many hours over the past few days trying to get sound working on my PC. A life without gaming is getting me down! I have searched hundreds of forum posts but can't seem to resolve...
Sound won't work form Speakers but works in headphones
Hi everyone, I have Sony Vaio CW26. Yesterday Sound stopped working from Speaker, it's still working from headphones. I tried to restore the system but the farther point I found was done 3 hours ago...... anyway, I found out too that the USB port ( which is next to the audio output) is not...
Can my sound card make 5.1 speakers work?
Hi, I'd like to buy a set of 5.1 surround speakers, but I don't know wether my sound card is able to make 5.1 speakers work, and I can't seem to find the answer by googling...:cry: So, I used Everest to identify my sound car : it seems I've got two : ...
HP620 No sound from speakers only headphones work
HP620 laptop running windows 7 32bit Home Premium Plugged in headphones for an hour. When I removed them the laptop speakers no longer function. Checked volume and mute. Checked playback device area and laptop speakers are enabled and indicated as functioning. Only headphones work. Deleted...
Sound card controls only headphones, not speakers!
Hi. I have a sound card problem after I installed Windows 7. Previously I had Windows XP and after I replaced OS some days after I noticed something weird - I can control headphones ONLY (volume, balance etc.) but my built in speakers are living completely independent life.:shock: If I`m playing...
Realtek hd problem..headphones work as speakers..
HELLO, I have a wired problem with realtek hd r237 windows 7 drivers: I don't have any sound on laptop's internal speakers but i can hear in headphones.In PLAYBACK DEVICES headphones are detected as speakers and when i unplug them sound automatically turns to SPDIF- no sound on internal...
