Windows 7: Microphone not recording anything but white noise
01 May 2014   #1
gavinsco
Windows 7 Home premium 64bit
So, my mxl 990 microphone works on other computers, but on my windows 7 pc it registers absolutely no change in volume whatsoever as the sound level is always at full volume. If you record the input, it sounds like a very quiet high pitched white noise and records no other audio. Changing input levels affects nothing and I have ruled out feedback or any similar problems with the actual microphone. It must be the computer. HELP!
05 May 2014   #2
andrew129260
Windows 10 Pro
You could try uninstalling the hardware and reinstalling it in device manager.
Tutorial:
Uninstall Device and Device Driver
10 May 2014   #3
gavinsco
Nope, didn't work.
Static/White noise in Windows 7 x32
I am experiencing audio static in my earphones. The noise increases with the increase in volume. I have realtek HD audio installed in my PC. I dual boot with ubuntu and i don't experience any such static while working in ubuntu. I have tried the DPC latency checker and the max latency is 184 s
A zoom (White noise?) i cant get rid of, Audio problem?
Hi there, i got this problem since i reinstalled windows ultimate on my laptop. I tried reinstalling windows, tryed different drivers and still i cant get it to stop. My laptop cable is connected on to a screen and the plugs are in a grounded outlet.. This sound only comes up when i get...
Mic white noise when recording
Hey all I've tried multiple microphones and also tried an USB audio card(adapter?), but still got the static background noise. The microphones worked well on my laptop, got nice and crisp sound there. Also, when I click listen to this device on microphone settings, I get clean audio as well....
Laptop Mic Giving Noise of when recording started
Hi Guys I have been starting to make voice overs for my videos recently using a Turtle Beach x11 headset and everything has been working ok. Suddenly whenever I start recording I get this like popping sound (like when you pop your ears) lasts for about 1-2 seconds and I dont know how to get rid...
Stereo Mix Echo + White Noise When Recording Fix!
Hey, many people have a problem, when recording Pc games, and want to record sound for games, well stereo mix records it, but if you turn up the sound, it echoes and makes white noise, well i have a fix! all you have to do is........ 1.Go to the sound Icon and right click it, then click...
Little Noise When I Am Recording
Hi everybody, I have at least 10 hours of searching for some solution but Google could not help me. :cry: Please listen my audio example, just ignore my spanish but listen carefully. What's the problem? I recorded with Samson C01U. Windows 7. An a new Dell 1545 Laptop.
