Windows 7: Mic white noise when recording
02 May 2014   #1
malloc
Win7 Ultimate 64bit
Hey all
I've tried multiple microphones and also tried an USB audio card(adapter?), but still got the static background noise. The microphones worked well on my laptop, got nice and crisp sound there. Also, when I click listen to this device on microphone settings, I get clean audio as well. I've tried recording with audacity, windows default sound recorder and OBS.
I have microphone settings set to 100% recording volume and 0 Boost (found the static to be lowest on these settings).
Also, some programs like Mumble seem to reduce the static ( while skype, OBS, raidcall, audacity etc don't)
my mobo is
Asus P8-Z77V LE Plus and i use the default sound card ( Realtek® ALC889 i think? )
Just recently upgraded drivers for it, didn't really help.
02 May 2014   #2
fireberd
Do you get any noise when just listening to audio? Just wondering if its a playback problem rather than a recording problem?
My recording studio backup PC is using this same motherboard and an i5 3550 CPU.
02 May 2014   #3
malloc
Win7 Ultimate 64bit
No, playback quality is really good.
If it matters, my CPU is i5-3570k
EDIT//
I got it a lot better with uninstalling the Realtek drivers and just using the windows default drivers. I can give more feedback tomorrow when I get to test my production microphone, headset mic quality improved a lot, tho.
03 May 2014   #4
fireberd
The Windows installed HD Audio Codec are just generic, basic function drivers. They do not have the full features of the chip's drivers (in this case RealTek).
I am using the ASUS supplied RealTek drivers on my motherboard, but the direct from RealTek drivers will also work. If you were using the ASUS supplied RealTek drivers, try the direct from RealTek R.273 drivers.
RealTek Drivers
Static/White noise in Windows 7 x32
I am experiencing audio static in my earphones. The noise increases with the increase in volume. I have realtek HD audio installed in my PC. I dual boot with ubuntu and i don't experience any such static while working in ubuntu. I have tried the DPC latency checker and the max latency is 184 µs
A zoom (White noise?) i cant get rid of, Audio problem?
Hi there, i got this problem since i reinstalled windows ultimate on my laptop. I tried reinstalling windows, tryed different drivers and still i cant get it to stop. My laptop cable is connected on to a screen and the plugs are in a grounded outlet.. This sound only comes up when i get...
Microphone not recording anything but white noise
So, my mxl 990 microphone works on other computers, but on my windows 7 pc it registers absolutely no change in volume whatsoever as the sound level is always at full volume. If you record the input, it sounds like a very quiet high pitched white noise and records no other audio. Changing input...
Laptop Mic Giving Noise of when recording started
Hi Guys I have been starting to make voice overs for my videos recently using a Turtle Beach x11 headset and everything has been working ok. Suddenly whenever I start recording I get this like popping sound (like when you pop your ears) lasts for about 1-2 seconds and I dont know how to get rid...
Stereo Mix Echo + White Noise When Recording Fix!
Hey, many people have a problem, when recording Pc games, and want to record sound for games, well stereo mix records it, but if you turn up the sound, it echoes and makes white noise, well i have a fix! all you have to do is........ 1.Go to the sound Icon and right click it, then click...
Little Noise When I Am Recording
Hi everybody, I have at least 10 hours of searching for some solution but Google could not help me. :cry: Please listen my audio example, just ignore my spanish but listen carefully. What's the problem? I recorded with Samson C01U. Windows 7. An a new Dell 1545 Laptop.
