Windows 7: Experiencing (Very) Low Sound Output on ASUS A8He
02 May 2014   #1
Giga
Windows 7 Ultimate 32-bit
Hello, members of Seven Forums!
Well, I upgraded my laptop's operating system from Windows XP (Professional) to Windows 7 (Ultimate) on November 2013. The experience was great except for frequent slowdowns, but I guess I'll get used to it.
Going to the query: I use a VoIP software called "Teamspeak". I plugged in my microphone and speak. The people in the channel I'm in told me that they cannot hear me properly. So while fixing my microphone, I decided to test the microphone settings from the Teamspeak's sound capture settings. It's positive, I can hear myself but it's very, very low. I twisted the microphone jack to see if that will fix it, but nothing happens.
I then traced that it is using my laptop's in-built microphone. Meaning, the microphone jack is not working. I tried to use other microphone, but it's still the same. So as an alternative, I used a USB sound device and the microphone worked.
However, I don't want to use a USB soundcard. I tried to resolve this problem by searching for solutions through Google, but I don't find any results of a similar problem. So I decided to download the driver of the laptop's sound card from the OEM website. However, there are no drivers for Windows 7, so I used the available driver for Windows Vista. The driver installed successfully and the microphone works again. HOWEVER, the sound output (playback) is veeerrryyy low. I maximized the volume from the volume control and the headphone's volume, but it's still the same.
Since I was annoyed, I uninstalled the driver, and the sound was back to normal. I'm not sure if this is called by the driver (because it's a Windows Vista driver), although I can say that this laptop is old (7 years old). It is still working though.
Quote:
TL;DR:
When using the default "High Definition Audio Device" (no driver installed):
  • Sound output is excellent
  • Microphone jack does not work
  • Uses the laptop's built-in microphone
When ASUS' sound driver is installed (although it's a Vista driver):
  • Sound output is very low
  • Microphone jack is working; input volume is good; built-in microphone is used when a microphone is not plugged in.
Does anyone know any solutions? I'm thinking about modifying the driver file so it will install only the microphone, but is that even possible?
Looking forward for your response. Thanks!
02 May 2014   #2
fireberd
The Vista driver is compatible with Windows 7. Basically, Windows 7 is just "Vista improved". The "High Definition Audio Codec" is the generic, basic function, Windows installed driver.
You can only have one driver installed. Two drivers installed, even if it were only one function, would conflict.
What is the actual sound chip? e.g. Realtek ALC888, IDT, etc? Depending on what you have there may be an alternate driver.
If you have the ASUS driver installed, uninstall any other sound driver (not just disable it) to avoid conflicts.
On a different subject, you only list Malwarebytes as your Antivirus. That is not an Antivirus program, its just for malware/spyware. If this is the case you need to install an Antivirus program. The free Microsoft Security Essentials is a good Antivirus program.
03 May 2014   #3
Giga
Thank you for the response, fireberd!
There are three sound drivers installed:
  • SoundMAX Integrated Digital HD Audio (The sound driver);
  • Unimodem Half-Duplex Audio Device (seems to be connected to "Motorola SM56 Speakerphone Modem", which is the dial-up driver);
  • Virtual Audio Cable (should be self-explanatory)
I already installed the SoundMAX driver even before Virtual Audio Driver was installed. I'm not sure about the Unimodem though. Is it safe to uninstall that driver?
Hmm.. How do I find what's the actual sound chip of my laptop?
Noted. Thanks for the advice!
03 May 2014   #4
fireberd
The SoundMax is your sound card. \\
The Unimodem is the dial-up modem. It shouldn't cause any problems.
The Virtual Audio Cable, is another issue. It MAY be causing some of your problems. Disable that and then reboot and see if it makes any difference.
03 May 2014   #5
Giga
It seems that it doesn't make any difference. Everything is still the same, sadly.
03 May 2014   #6
fireberd
Has the microphone port ever worked? Did it work OK in Windows XP?
ASUS N53SV-XV1 experiencing BSOD at random
I have an ASUS N53SV-XV1 that has been getting BSOD during normal (browser, outlook). It goes BSOD at random and happens 1-2 a day, during an 8 hour work period. Make and Model ASUS N53SV-XV1 Display 15.6-inch LED-backlit Full HD display (1920 x 1080) Graphics Card NVIDIA® GeForce® GT...
BSOD Help and Support
Experiencing problem with sound on MPC
Last night i attached my laptop to to my HD tv Via HDMI cable to watch something. I was using media player classic. After film finished i disconnected cable. This morning i went to use media player classic and there was no sound, still have sound with other media software. Sound works if i plug it...
Asus M4N68T-M NO AUDIO OUTPUT DEVICE IS INSTALLED
I HAVE Asus M4N68T-M I AM USING WINDOWS 7 I AM NOT GETTING SOUND I HAVE DONE EVERY TROUBLE I AM UNABLE TO FIND PROBLEM CAN SOME ONE HELP ME I HAVE UPLOAD PROBLEM PICS ON PHOTO BUCKET No Audio Output Device Is Installed Photos by azheruddin | Photobucket
Gigabyte HDMI output to Yamaha receiver - no sound output
GA-890GPA-UD3H (rev. 3.1) GIGABYTE - Motherboard - Socket AM3+ - GA-890GPA-UD3H (rev. 3.1) (Note 3) Simultaneous output for DVI-D and HDMI is not supported. What I'm trying to do is output just my sound to the receiver via HDMI cable, but still use the DVI to my monitor...
How can I get sound output from sound card when streaming video?
I get sound from the mic of course.but I would like to get sound straight from the sound card too when I want to.I don't know exact model,but it's a realtek HD on board sound card.Acer 5551 series laptop
Sound Output
Hi, I'm a college student with a desktop computer. Whenever I come home, I leave my speakers at school. I used to have Windows Vista. When I'd come home, I could listen to music without headphones or speakers. In other words, sound would come from my sound card. I now have Windows 7, which...
